07-01-2016, 08:11 PM
Jackson
, Wyoming
TV Mount - not moving
I am having difficulty moving the TV wall mount in the bedroom of our 2015 International 25FB.
The tv turns slightly on the mount, but the arm won't extend completely.
I feel like I am missing something.
Does anyone have any tips on how to move tv into viewing position?
Thanks!!
07-01-2016, 08:19 PM
2016 26' Flying Cloud
London
, Ontario
Thanks!!
Look for a strap behind TV and pull straight down on it. Here's my front TV. This will release the pin and TV will angle outwards. Can be tough on the small bedroom TV.
You're a long time underground!
07-01-2016, 09:24 PM
2014 25' FB International
airstream
, zero
07-02-2016, 09:41 AM
London
, Ontario
Here's a photo of the rear of the bedroom TV. You can see the strap and release mechanism. That pin can get sticky, so a shot of oil does wonders for loosening it up. A sharp pull straight down on the strap also helps.
07-02-2016, 12:42 PM
2015 25' Flying Cloud
GILBERT
These are some of the GREAT THINGS the dealership forgot to show you.
Welcome to the world of learning new things.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
07-02-2016, 01:12 PM
2016 19' Flying Cloud
Morrow
, Ohio
3n1 oil ok ? Thanks Cleecooper for posting . Lol I jumped right on this post cause I have been staring at TV hoping it would open all on its own .
Will TV run off inverter ? I have a plug right behind TV so I thought it would but doesn't come on . But this is actually the first time I have tried TV .
07-02-2016, 02:44 PM
London
, Ontario
Yes to the oil or even WD40.
Did you turn the inverter on? The plug has to be connected to the inverter and AS usually puts a blue sticker on the plug indicating it accesses the inverter. You also have to program each TV to get over the air channels or cable stations if you're hooked up to a TV cable service. Do this through the menu of each TV.
07-02-2016, 05:23 PM
Morrow
, Ohio
I had lights on so I know I had inverter on but nothing camped on . Also plugged into plug with blue sticker , even tried other one just in case LOL . At work tonite so I'll go out tomorrow to see if I can program but I did not see anything light up ... after a short trip I found the cover of TV had popped off - it did snap right back on . Thanks !! Hopefully programming will work ...
07-02-2016, 06:40 PM
London
, Ontario
Fresh batteries in the remote....
07-03-2016, 03:38 AM
Morrow
, Ohio
That battery thing did zip thru my brain briefly , LOL then gone . Will change them . It's a 2016 so shouldn't be but....I know dealer must have had TV on cause battery were installed .
07-04-2016, 06:20 PM
Morrow
, Ohio
Ok . Batteries good cause remote lights up . Can I use the CGFI tester dealer gave me to see if that inverter plug is getting power ? I have not tried the TV since I bought trailer so IDK if it's TV or a power issue . Thanks .
07-04-2016, 06:39 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
If you decide to lubricate it, recommend you use silicone spray. There are some rubber bushings in there. You can also use silicone grease. Available at HD or Lowe's.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
07-04-2016, 06:51 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
Nininet, the lights work off 12v battery, they would come on without nverter coming on.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
07-04-2016, 10:53 PM
Morrow
, Ohio
Thanks BAB !
Oh , I thought they worked off inverter when not hooked to shore power . I tried a small lamp in all the inverter outlets and when none would light it up I thought it meant that something was wrong . So the inverter works off shore power ? I thought I was supposed to use them when boondocking . I checked the breaker and fuses and all were okay but one was inserted wrong - the top prong of a 15 amp fuse was not in slot , the bottom prong was . No damage from that possibly ?
Guess it's a trip up to a park to hook up to power tomorrow to see what really works .
05-31-2017, 04:06 PM
2019 27' Globetrotter
Missouri Valley
, Iowa
I have the same TV bracket as LilBigfoot in post #2 in my 2017 26U FC bedroom. How do you adjust it so that the TV has tension to keep it from pointing / tilting downward. I tried to adjust allen head set screws but to no avail. The manual probably tells but so often this forum has simpler, easier to understand solutions to problems. Thanks for any help.
Dan
06-01-2017, 11:29 AM
2015 25' FB Flying Cloud
Manassas
, Virginia
Dan
I believe it is the allen screw on the part of the mount with the curved edge near the back of the TV. You may need a wrench on both sides of it and it may feel pretty tight already but you can snug it up more. Make sure you have the TV in position prior to tightening - an extra set of hands would help here.
06-01-2017, 01:41 PM
Missouri Valley
, Iowa
Thanks, 'Nerd. I'll give this a try. I knew it would be simple.
Dan
06-01-2017, 05:14 PM
Sag Harbor
, New York
It may be worth your while to buy individual Allen wrenches to get the leverage you need to make up that joint more tightly IMO, as opposed to the small sets of Allen wrenches which are fastened together as a set. We have a set of T-handled ones you can really crank on. Sears used to sell plastic bagged sets of individual wrenches which would also let you get some leverage on both sides of that joint.
Good luck!
PS -- Edit -- Ours does look like the photo in Post #2, but it does not accept an Allen wrench on both sides. You may have to use a Vise-grip to grab the bolt head on the back side, although there is not much of one sticking up. If the Allen wrench makes the other side spin, without tightening things up, you may have to replace the bolt with a custom set up which permits a tool to hold each end of things.
06-01-2017, 07:21 PM
Missouri Valley
, Iowa
OTRA15 - you are so right on the allen wrench comment. I've got both. The folding combo set is good only for things like adjusting the mirror on a bicycle!!! I have some of each, including a T-handle set in a Sears socket / allen combo pack.
Dan
06-02-2017, 10:20 AM
Missouri Valley
, Iowa
I was able to cinch down the TV tilt bracket in the bedroom of my 2017 26U FC today. I found 2 set screws, one on top and bottom, taking a 1/8" allen to loosen before I could use the 5/16" allen to tighten the pivot point. Extra hands do help, but you can lean a bit on the TV to keep it in position to tighten. OTRA15s advice on a proper allen wrench is useful, too. Thanks!!
Dan
