Old 11-23-2010, 06:56 AM   #15
dznf0g's Avatar
Oswego , Illinois
I would also add, as a note for those of you who have this pocket door setup, that there is very little clearance between the back of the wall and the pocket door for a backing plate etc. Interference can cause scratches to the door. I used the self-adhesive floor protectors (the kind you use under furniture, etc.). They are available in many shapes and sizs. I chose the strips about 4" long and 1/2" wide. I ran several of them horizontally across the leading edge of the reinforcement plate to create a "padded ramp" for the door to slide on.
Also, you must remove the door and loosen the BR wall screws in order to allow room for your arms and hands to get in between the walls. If you have "Popeye" arms, you may have to get a small assistant to help.
Old 11-23-2010, 10:50 PM   #16
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I decided not to mount the flat screen, instead I found that my 26" sony would sit on the cabinet top attached to the credenza. My wife and I could both see the tv fine sitting in our recliners. While travelling i just put it on the bed, works fine for us
Happy Thanksgiving,
Reganzo
Reganzo is offline   Reply With Quote
Old 01-29-2011, 07:13 PM   #17
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Thanks for all the suggestions, we followed what many did in terms of location and devised a plan for the back side of the mount to dual purpose as a magazine rack. Turned out decent and for the 15" TV seems to hold up and support quite well. Wifey came up with the idea and is comprised of some 2x2's. Rack only holds 4 or 5 mags but turned out decent!
Total cost $30 including the mount which we found on overstock.com.
ID:	120419   Click image for larger version
NicheVintage is offline   Reply With Quote
Old 01-29-2011, 08:40 PM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That looks great!
Are you guys going to be at DH5?
Richard
Old 01-29-2011, 09:21 PM   #19
1965 26' Overlander
Images: 34
Thanks for the help on this one
As for DH5 we will be there half polished and all. We can't wait. I dropped the registration in the mail today.
Old 01-30-2011, 05:34 AM   #20
2002 25' Safari
Dewey , Arizona
Images: 62
I could bring my Cyclo...
Richard
Old 01-30-2011, 10:03 AM   #21
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Originally Posted by azflycaster View Post
Just to follow up what Zep said. This is the end result of my TV mounting. The TV will be detached when traveling leaving just the bracket on the wall. The TV can be rotated around the partition and will then be viewable from the front area for the trailer. When not in use the power cord and signal cable will be in an overhead out of site.
Do you still find it okay to remove the TV when you travel, or has it become a pain? We have the lovely '70's 1/4 thin laminate wall dividers, and are unsure as to how well traveling with the TV mounted "ON" the mount will be (even strapped in).
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 01-30-2011, 10:39 AM   #22
1965 26' Overlander
Images: 34
The mount we purchased makes it easy to take the tv down for transport. We too have the 1/4 inch walls. We added a 2 x 2 behind for more support. I don't want test our luck and leave it up while on the road.
Richard, one can only dream about finally getting to the cyclo stage. Will this thing ever be finished?
Old 01-30-2011, 10:46 AM   #23
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
Do you happen to have a link to the one that you purchased? It is some sort of quick-release mechanism that removes it?
-Shawn
TAC OK-42
Old 01-30-2011, 11:41 AM   #24
1965 26' Overlander
Images: 34
Here is the link. It's a nob you unscrew closest to the mount attaching to the tv.
Mount-It! Dual Arm Articulating Flat Panel Monitor Mount for 13 to 30-inch Screens | Overstock.com
Old 01-30-2011, 06:02 PM   #25
2002 25' Safari
Dewey , Arizona
Images: 62
We have this one:
LCD Wall Mount with Articulating Double Arm System | Overstock.com
It has 4 screws that hold the TV to the mount and it takes two minutes to get it attached.
Richard
Old 01-31-2011, 07:38 AM   #26
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Shawn I had no trouble with the wall supporting the arm and a 22" Vizio through the panel over the fridge in my 72. Drilled three holes through it to mount. I usually took the TV off the mount during travel. Could also rotate the arm into the back room to watch TV in the twin beds.
RichHog is offline   Reply With Quote
Old 01-31-2011, 08:31 AM   #27
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
Thanks...I think that's what we're going to do -- I just didn't think that wall would be able to support it while traveling (although I know plenty of people who do with newer models). At the same time, I don't want it to be a pain having to always unscrew and re-screw something (and risk messing up threads, etc).
-Shawn
TAC OK-42
Old 02-01-2011, 08:01 AM   #28
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I think the three screws balance out the weight of the mount and my wall was secured by the overhead bin and the counter/fridge frame. I usually took the TV off the arm during travel as a precaution but if you create a strap (I used a bungy cable to keep the Vizio secure against the wall) it should be fine.
television mounts
TV mount for 96 25 ft jasper2222 Audio, Video & TV 1 11-18-2009 01:08 PM
TV Mount ? TLH67 Audio, Video & TV 5 11-13-2009 07:13 AM
tv mount millvalleyca General Repair Forum 17 08-03-2008 12:00 PM
Flush Mount or Surface Mount Skycop Water Heaters, Filters & Pumps 10 01-13-2008 06:59 PM
Where to Mount CB ? bubbleup Land Yacht/Legacy Motorhomes 2 08-18-2006 10:29 PM
