Old 11-12-2009, 08:31 AM   #1
TV Mount ?
Another mystery in our " new " 1967 ---Is this an old TV mount?
I think so , but cant find any other pictures of it !
Thank you !
Lisa
TLH67 is offline   Reply With Quote
Old 11-12-2009, 08:34 PM   #2
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
TV Mount?
Lisa,
We had one of those in our prior Airstream (1967 Tradewind). Yours is missing the "swivel table" that connects to that mount. I don't know if it was intended for a TV or simply a table to place things onto ... but ours was located in the twin bed area of the Tradewind. We did some restoration work on our Tradewind prior to selling it ... we ended up removing that mount and the connected "swivel table" and it now sits on our garage floor. I can take a photo of it in the next few days and email a photo if you want to see what it looks like.
Frank&Mike is offline   Reply With Quote
Old 11-13-2009, 03:57 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Photo of an original mount (courtesy Vintage Airstream) and then modified to accept a flat screen:
ID:	90804   Click image for larger version
Old 11-13-2009, 05:09 AM   #4
AH ha ! i KNEW IT !! tHANK YOU BOTH FOR THE INFO !
i WILL BE ON THE LOOKOUT FOR THE MISSING PIECE --ALTHOUGH I WAS TRYING TO CONVINCE MY CHILDREN WE DONT NEED A TV IN THERE...
Old 11-13-2009, 05:41 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The original mount will actually rotate all the way around so you can view the tv from the sofa also.
Old 11-13-2009, 07:13 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
And if you modify it to accept a flat panel as above, you will have a spot to put a small DVD player.
tv mount millvalleyca General Repair Forum 17 08-03-2008 12:00 PM
Flush Mount or Surface Mount Skycop Water Heaters, Filters & Pumps 10 01-13-2008 06:59 PM
tire mount codybear Tires 21 02-03-2007 02:16 PM
Where to Mount CB ? bubbleup Land Yacht/Legacy Motorhomes 2 08-18-2006 10:29 PM
LCD TV Mount tandemfish Argosy Motorhomes 4 01-20-2006 06:33 AM
