Old 08-12-2013, 02:19 PM   #1
jornvango's Avatar
TV hookup
Next to the inside connection for the TV, there's a small button which, when slid to the left, makes a small light burn.
Any idea what this is for?
I haven't had a chance to test it out yet if it does anything, but have noticed in the past that our TV signal when hooked up to a cable on a campground is pretty staticky.
See attached image.
Thanks.
jornvango is offline   Reply With Quote
Old 08-12-2013, 02:22 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi - I'm guessing that's the button to turn on the power to your tv antenna (for watching air channels) and to turn it off (if watching cable tv connected from the campsite).
Not sure though - yours looks different than mine....
Old 08-12-2013, 02:37 PM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
It does turn on power to a signal amplifier.
In the "batwing" style of antenna, the amplifier is in the center part of the antenna. The wall plate switch sends 12 volt power up the coax to power it.
However, a red light at the wall plate just means power is on, the amp could be bad. The UV light breaks down the plastic of the antenna. Water gets in and corrodes the circuit board.
Hook a TV up to the coax connector, raise the antenna and turn on the amp.
Make sure the tv is in "air" mode and do a channel search.
They work really well, all things considered.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-12-2013, 04:08 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
On our rig it's a push button ... but it's no doubt the antenna booster. It needs to be on (lit) to use the roof-top antenna.
TB & Greg and Abbey Schnauzer
#3954
Old 08-12-2013, 05:06 PM   #5
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Yeah, it is the slide switch for powered roof antenna "booster".. If you are plugged into a cable system, at an RV park, the booster should be OFF, as it screws up an otherwise good cable signal.. When using solely the roof antenna (hopefully fully extended and properly aimed, and within range..) it will make the signal sharper sometimes..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 08-12-2013, 08:09 PM   #6
jornvango's Avatar
Thanks, I tested it and it does have a significant effect on the quality if some TV stations on antenna.
Old 09-20-2013, 08:16 AM   #7
Crusty's Avatar
1992 34' Excella
I've been fighting intermittent signal dropout to my tv for some time and based on this thread I bought a new amplifier plate. After installing it the problem was eliminated and as I looked over the old one I found that the power fuse connections were loose, allowing the fuse to rattle around in the sockets and intermittently disconnecting power to the amp. If you're having this sort of problem take a look at the terminals for the fuse legs because that could be your problem.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
