Old 10-18-2008, 09:56 AM   #1
2008 16' Bambi
Des Moines , Iowa
TV Digital Converter Installation
Has anyone put in a Digital Converter for their TV system. We need to do one in our Bambi before the Feb. 2009 change to TV broadcasting. Any experience/advice out there?
Thanks, Keith
okeithbowman is offline   Reply With Quote
Old 10-18-2008, 10:37 AM   #2
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
A 2008 Airstream International has the digital antenna. If you have the 19" LCD you are okay, if you have the 15" LCD you will need the converter box.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 10-18-2008, 10:44 AM   #3
2006 F350 V10 Ext. Cab LB
Driver1's Avatar
1998 30' Excella 1000
Sherwood , Oregon
Images: 12
Hi,
What's the digital antenna look like? Any pictures?
Walt
Driver1 is offline   Reply With Quote
Old 10-18-2008, 10:55 AM   #4
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
I have installed the digital converter; everything seems to be ok. I am going to try the free channels, but I am am still considering cable. Good luck in your decision.
willyd is offline   Reply With Quote
Old 10-18-2008, 11:05 AM   #5
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
There is no such thing as a digital antenna. Any amplified VHF/UHF antenna (most stations are broadcasting in the UHF with their digital signals) will work just fine.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 10-18-2008, 12:10 PM   #6
1968 17' Caravel
Images: 79
Sorry, I explained it wrong. The Winguard Antenna used in the 2008 models is capable of receiving local channels in razor sharp High Definition without any additional hardware to purchase, when used with the 19" 22" or 23" LCD HD TV's.
Old 10-18-2008, 01:15 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The original folding antenna on our 1965 Caravel picks up local broadcast digital high definition signals that are clear as a bell on our 20" Vizio we got from Costco a year and a half ago.
Any antenna that picks up a UHF signal will work with your digital to analog converter box or with your TV of any size that has a digital tuner. In the past, there were many flat screen TVs sold that were "high definition ready" or "digital ready". Those TVs do not have a digital tuner, only an analog tuner. They need a digital tuner added to get digital/high definition, or a digital to analog converter box to continue to work over the air.
Old 10-18-2008, 01:28 PM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
A funny/not so funny story
A friend of ours had a nice Country Coach motorhome he bought new five or six years ago. "Joe", I will call him, is a nice guy and very handy with his hands. He is a reasonable man and puts one word after another and forms complete sentences. However, he is very stubborn, especially when it comes to being wrong.
Well, last January at Quartzsite, Joe was talked into a device to add to the folding TV antenna on the roof of his coach that is supposed to enhance the digital signal to his TV. Joe is convinced that his analog TV is now capable of using the digital signal over the air when the analog signal goes away next February.
Many people do not realize that the digital/high definition broadcasts over the air have been going on for some time now. The only change will be that the analog will stop.
Wouldn't you just love to be a fly on the wall of Joe's Country Coach next February, on the day when there is no more analog signal? I sure would.
Old 10-18-2008, 02:52 PM   #9
HowieE's Avatar
Princeton , New Jersey
Images: 12
Any antenna, including the fillings in your teeth, will pick up a digital signal. There is no reason to change any currently working antenna. In fact many will find that the old dipole antenna on the roof at home, with a converter, will bring in a much better signal than cable or satellite and cancel their local station subscriptions.
The problem is that any TV that does not have a digital ready tuner, and most do not, will require a converter.
I have set my trailer up for the following signals, analog off the roof antenna, digital off the roof antenna, campground cable, and satellite. The picture below shows the wiring.
2004 Excursion 4x4
Old 10-18-2008, 07:29 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Much better. This, I agree with.
My old Braund Skyliner works perfectly with my Mitsubshi 1080P HDTV. Makes DVDs look bad.
Vaughan
Old 10-18-2008, 09:31 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
One thing that some may not know
One thing that some may not know........
The following applies to over the air, not cable or satellite.
Digital channel numbers are different from analog channel numbers.
For instance, in the Los Angeles area,
2 is analog, 2-1 is same programming,,digital
4 is analog, 4-1 is same programming, digital
4-2 is weather
4-4 is News Raw
You may get more digital channels than analog.
Not all digital is high definition.
Most will broadcast their High Definition (720p or 1080i on their -1 digital channel, some will also broadcast the same program in standard, 480 definition on their -2 channel.
If you are not receiving the -1, or -2 signal, you are still watching an analog signal, not a digital signal.
Some digital is in the newer, wide screen 16x9 format. Some digital is broadcast in the old 4x3 screen format. On occasion, you will see digital, high definition, in the old 4x3 format, but not so much anymore. Most high definition is now 16x9 wide screen.
Hope this helps some.
Old 10-19-2008, 12:13 AM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Digital Converter box.
Hi, I just got my first digital converter box for my home TV. Mine has analog pass through. It works great so far, but with my antenna in the direction it has been in for a long time, It tells me I need to adjust my antenna to receive a few stations that I had no problem receiving before. My question is: When I put my next converter box in my trailer, will I have to set it on "pass through" mode to get my best TV signal, then do a channel scan to fine tune the best antenna direction, and finally switch it to digital mode and reprogram the whole thing again? Or, will a satellite TV signal finder work in my trailer to find the best direction for my antenna?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-01-2008, 10:13 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
DTV Interference from Fantasic Fan?
We installed a DVTPal+ analog-to-digital converter on 06 19' Bambi's Sony TV. We went to the Sony website and found that our particular TV was not DTV ready...so we got the converter. (It's a "pass-through" box, so we can still get analog signals when we want.) The digital reception is great and the picture is beautiful. However, when we turn on the Fantastic Fan, it causes interference that disrupts the digital image... Anyone know if there's an interference filter we can get add to stop the interference and where it should be placed?
TB & Greg and Abbey Schnauzer
#3954
Old 11-11-2008, 05:18 PM   #14
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
May have been a little premature with our last post about interference from the Fantastic Fan...we now believe it was because we had a weak digital signal at the park where we were...when we re-scanned at home in the city, we not only got a lot more channels, but they all look great while the Fantastic Fan running... Glad it's not a big issue.
#3954
Converter Installation on a 63 1963tradewin Batteries, Univolts, Converters & Inverters 2 08-11-2008 03:46 PM
Just added a Digital Converter to TT HowieE Audio, Video & TV 8 06-14-2008 09:46 AM
Digital TV Antennas Pop Rivet Audio, Video & TV 19 02-23-2007 09:12 PM
Digital TV jcanavera Audio, Video & TV 3 02-02-2007 10:51 AM
digital clock sovereign General Appliance Topics 3 08-06-2002 11:21 PM
