Old 04-02-2004, 10:29 AM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
TV connected & on shore power?
Is there anything "wrong" with my leaving the 12V hooked up to the tow vehicle when I do not unhitch and connect to shore power for an overnighter?
Not that I'm lazy or anything.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 04-02-2004, 10:36 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I don't think so. the univolt would actually charge up your tow vehicles' battery in that configuration.
Old 04-02-2004, 12:10 PM   #3
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I see no problem.
I usually leave mine hooked up overnight. I have never ran into a problem in 15 years of doing so. That way, I don't forget to plug it in during some of my early-morning departures.
John W. Irwin
WBCCI #9632
Old 04-02-2004, 03:27 PM   #4
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
If your Expedition is anything like the bigger Ford trucks, there's a relay that connects the truck alternator and battery to the trailer 12V circuit when the ignition key is in the "Run" position, and disconnects it when it's in any other position, including Off with the key removed. This keeps the trailer from draining the truck battery (and also keeps the converter from charging the truck battery).
Maurice
RoadKingMoe is offline   Reply With Quote
Old 04-03-2004, 05:12 AM   #5
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
My 2000 GMC 3500 had dual batteries, and the relay that Moe speaks of. It kept the aux battery connected to the trailer at all times, but isolated the main battery from the trailer. Not sure how the diesel is as I believe it uses both batteries for starting. I'll have to throw a VM on that pin of the rear connector and find out.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Installing TV, DVD, and VHS in your trailer Shelby Copeland Audio, Video & TV 73 04-08-2007 07:44 PM
Thoughts on flat screen tv yukionna Off Topic Forum 15 09-16-2003 08:40 AM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 05:11 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
