Old 01-01-2010, 12:11 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
TV Audio Improvement
Our last 2 Airstreams had the TV mounted on a wall that was a distance from the couch or sitting area. To hear the TV the sound had to be cranked up to the point of deafness if someone was standing by the TV.
I believe that I have cured this situation by adding a speaker kit offered by Bose. It has 2 very small speakers with a base box. The unit plugs into the headset outlet on the back of the TV. The base box (maybe called a boon box) is on the floor under the table. I have not decided if I want to mount the 2 small speakers or for the time being just lay them where we want them.
Its a fairly cheap answer to the problem of hearing the TV for those of us who have hearing problems.
gaylejoe is offline   Reply With Quote
Old 01-01-2010, 12:18 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Something less to stow
I think you will like the sound. I permanently mounted a similar system, and have thoroughly enjoyed the benefits.
Tom
Old 01-01-2010, 12:26 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Very creative solution to a small space/big sound problem.
Bose has solved our problem with the cr@ppy factory sound system.
IMHO... their Wave Radio/CD Changer sounds better than anything you could install in such a confined space, plus run the Television/blu-ray sound thru it and take it anywhere.
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
electrical improvement for under $0.10 Excella CM Electrical - Systems, Generators, Batteries & Solar 7 02-19-2007 02:35 PM
Little Adjustment, Big Improvement! thecatsandi Hitches, Couplers & Balls 2 06-08-2006 08:34 AM
Bambi Improvement Request DreamStream Our Community 2 01-24-2004 08:46 PM
Frustration_forum improvement ? femuse Our Community 24 03-27-2003 03:58 PM
