Old 11-20-2005, 02:29 PM   #1
Austin , Central Texas
TV Antenna Replacement
After much consideration, I have decided to replace the skyliner antenna with a batwing style Winegard. This is a two part posting.
First, can any one advise me what would be the most suitable batwing TV antenna? My '88 29' Excell is equipped with a booster. In considering the Winegard antenna, does my existing booster still apply or do I need to replace that booster with the Winegard amplifier? Any advice on the removal of the existing and/or the installation of the new would be greatly appreciated.
The second part of this posting is to say that I will have a used Skyliner that I will be parting with. It has suffered from some metal fatigue that sheared the base at the main mounting pin. The part that is damaged is the base assembly #12928. All other parts, including the worm gear are in fine condition.
FlyFishInn is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Replacement Antenna kntd Audio, Video & TV 6 12-05-2002 08:33 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
