Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 04-14-2018, 09:58 PM   #1
1989 34' Limited
Carmel , California
TV antenna replace and add special sauce?
Hi All,
So I have a bit of a strange one for you folks, I have a 1989 34' Limited with an antenna that looks like Edward Scissorhands left his claws behind (it's like this one)
I am thinking of repurposing the existing antenna raising and lowering device to mount a cell booster antenna, but I started thinking what if I could have both... I'm thinking of mounting an inexpensive antenna with a rotator on the top of the antenna mount and relying on its electric rotator to go channel surfing, then use the existing mechanism to rotate the cell antenna.
My concerns are as follow:
Will the antenna be strong enough to not fly off the airstream?
Will the rotator handle odd wind loads?
Will there be interference between the two antennas as one will be transmitting and will it be a problem?
Does anyone have any thoughts, concerns or advice?
RedBearded is offline   Reply With Quote
Old 05-15-2018, 08:01 AM   #2
2007 23' Safari SE
Annandale , New Jersey
RB, guessing my setup is a bit different, but unable to see the type of crank up mast you have. If similar to the batwing that came on trailers 10+ yrs ago, you may be interested in this one from King Jack that will lay flat, which you can get on many etailer sites for $43. Am told (will be installing this weekend) It clips right on to the batwing mast (dual square aluminum posts) and is a 5 min swap out.
I almost went with the more mushroom shape one that mounts a foot off the roof in order to get the signal meter, but found an app for my phone that points to all nearby TV/FM/AM antennas, so hoping that is sufficient.
BTW, almost forgot, but there is also a fitting to attach the head to a pole that comes with the head ifr you dont have the dual batwing standard mast.
Fred L is offline   Reply With Quote
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 07:11 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
F250 Fuel Tank - Add or Replace for more Capacity? Boogieshoes Tow Vehicles 24 09-13-2015 08:07 AM
Screaming Flamingo Hot Sauce soldiermedic Stella's Kitchen 13 07-25-2012 03:30 PM
