Old 12-26-2004, 07:41 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Question TV Antenna Repair/ replacement/ leaks
I have the original (1975) antenna for my Trade Wind. However it has been removed from the camper. I am thinking of restoring this an installing it again. I am not a big TV watcher while camping but it would be nice to have it available. We have a cool DVD surround sound system and prefer a good movie. There is very minor damage to the assembly. Nothing that can not be overcome. Suggestions??
balrgn is offline   Reply With Quote
Old 12-26-2004, 08:24 AM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
You can go to the Wineguard home site and down load the Installation and repair manual free.
Can't find the link so you may have to do a search to find the home site.
Garry
Old 12-26-2004, 09:18 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
find another one to look at
balgrn,
The best bet is going to be to find someone that has one and see how it is put together, unfortunately mine is no longer with the unit, it was replaced with a sattelite/antenna combo Is yours the electric or manual unit? I have a scan I can send you of an exploded view if you are interested. It is the one out of the 1975 service manual. It shows all the parts involved.
Just PM or email me with your preferred email address.
Aaron
WBCCI #XXXX AIR #2495
Old 12-27-2004, 10:48 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I have the same antenna, and also have the manual in pdf format if you need it.
the only parts I've seen online are the worm/wormgear replacement kit, and the crank handle. I just discovered that mine leaks like a sieve, so I had to remove it from the trailer (for now) and patch the hole. I may replace it w/ a new antenna, if I can't get the parts needed to fix it. In the process of removing it, I broke the crank handle and wound up destroying the crank shaft. If I can find a shaft, I may try to fix it. the only thing that I can see that keep water out is the o-rings that go on that shaft, and they should be available anywhere.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-28-2004, 04:05 AM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Antenna
I have a copy of the Parts list (Thanks AARON) I did not remove the antenna myself so I don't know what may be missing. It is TOO darn cold out (6º) to work on the roof right now. I'll be looking at the assembly and make whatever brackets I need to replace. I see the O-ring, I may need to address that soon, saw some moisture on the handle (could be condensation). I’m in the middle of re-assembling the bathroom, but need a break from that once in a while. I’ll be taking pictures of everything. Let me know if you need any?
Old 03-14-2005, 07:03 PM   #6
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Antenna Removal and Patching
I'm thinking of removing the antenna on a 73 Soverign and patching the roof.
Good idea or bad idea? Has anyone ever removed one and patched the roof with success?
1956Safari is offline   Reply With Quote
Old 03-14-2005, 07:21 PM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Ummm, if the antenna is any kind of of good shape, I'd like the first shot at buying it. Patching is relatively easy. Do a search of "roof repair", Skin repair, etc.
www.nesa.org
Air No. 6427
Old 03-14-2005, 07:32 PM   #8
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
Originally Posted by mediaetc
I'm thinking of removing the antenna...
Nice thread...I'm waiting to do the same thing when it warms up a little. I was just going to make sure I had a healthy bead of Sikaflex under the riveted patch (which is just like how I patched the tail light holes after I removed the stock lights).
One thing I love about vacations is getting away from the TV but I may replace it with a roof top FM antenna.
Best of luck,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 03-15-2005, 04:11 AM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
The PO my '75 removed the Antenna. I looked at it this weekend. The area has caulking around the area. No leaks so far. I have the original antenna, contemplating repairing it. (???)
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
Old 03-15-2005, 05:13 AM   #10
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
How about an update? There must be somthing better, a clean conversion.
My origional equipment antenna is like brushing snow off a skeleton laying on the roof.
fastrob is offline   Reply With Quote
Old 03-15-2005, 05:41 AM   #11
sfixx's Avatar
1973 Argosy 20
Images: 12
What would be cooler than the:
Winegard® Sensar II® Batwing TV Antenna
http://www.campingworld.com/browse/s...26655&src=SRQZ
Steve
Old 03-15-2005, 07:47 AM   #12
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Steve!
Steve
I have the batwing antennas on both my '64 Overlander and '78 Minuet. The antennas (with signal booster) provide wonderful reception and are very easy to operate. My Airstream dealer installed both of them - - the Overlander was missing all but the permanently attached pole and interior rotor for its original antenna and the Minuet had never been equipped with a TV antenna. The only thing to be considered, that I am aware of, is that they must be carefully mounted so that the "wings" don't vibrate against the roof while in-transit.
Kevin
Kevin D. Allen
AIR #827
Old 03-15-2005, 08:48 AM   #13
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Batwing
I just put the new model Batwing on and the new wings don't turn down as much as the old ones and they put four rubber pads under the head.
The two modifications seam to have elimanated the roof rub problem. I also painted the roof with cool roof which shows no rub signs yet.
Don
Gunnyusmc is offline   Reply With Quote
Old 01-30-2006, 08:38 AM   #14
canton , tx
TV antenna removal/ leaks/patches
the tv antenna (elec remote) on our79 mh does't work and there is a leak where the wire goes into the roof...I would like to remove it and patch the hole or replace it with a manuel type...I need some help with the procedure...the process is not obvious to my untrained eye...thanks for your help...joe
rvlover is offline   Reply With Quote
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
