Old 05-02-2007, 07:31 AM   #41
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Any suggestions on how to repair the antenna wire where it goes through the roof. I think mine has become intermitant at that point due to the strain of going and and down. I really don't want to tear off my internal panels to run new wire, but I'd be happy if there were some way to push some extra slack up through the antenna hole and slice in a new piece of 300ohm antenna wire up top. (I have the orginal non-rotating 1979 airstream antenna).
wacnstac is offline   Reply With Quote
Old 05-02-2007, 07:42 AM   #42
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
What kind of "cool roof"?
Originally Posted by Gunnyusmc
I just put the new model Batwing on and the new wings don't turn down as much as the old ones and they put four rubber pads under the head.
The two modifications seam to have elimanated the roof rub problem. I also painted the roof with cool roof which shows no rub signs yet.
Don
Can you specifically tell me what product you used on your roof?
trevisgardne is offline   Reply With Quote
Old 05-02-2007, 09:44 AM   #43
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Go Batwing
Do not waist your money on the Wineguard pancake antenna!
I thought was good idea, as not lowering or raising would be nice.
It works about as good as if I knocked off the batwing!
The old style fold ups are interesting too...add a amp and you would be set.
I patched hole by cutting a piece out to match attachment area of old antenna, made three non-touching doughnut circles with sealer, and pop-riveted it in place.
Used bytle<sp sealer from Depot, is gray and flows nice.
Is made for exterior panels that flex.
klattu is offline   Reply With Quote
Old 04-30-2017, 05:05 PM   #44
1978 29' Ambassador
Selmer , Tennessee
I need the pdf file on the antenna crank assembly we have a 1978. we are working on. thank you in advance please send to ctidwe@yahoo.com
ctidwe is offline   Reply With Quote
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
