Old 07-31-2007, 12:41 PM   #1
2005 34' Classic
Richmond , Virginia
TV antenna popped?
I was trying to drop my tv antena and the handle just starts to pop when closing. Its almost down but needs another 1/2 inch to go. Any Ideas?
Resorts is offline   Reply With Quote
Old 07-31-2007, 01:08 PM   #2
1992 34' Limited
Falls Church , Virginia
Not sure....but
Resorts -
Not sure of your exact problem, but I am willing to take a 'guess' at your problem.... I would venture a guess that it might be a 'striped' gear in the up/down system.... As I recall, on my SilverToy, it is a gear that the handle engages when you crank the antenna up or down.... These are known to strip when over tighten....
My guess.... hope it's as simple as that....! Be sure to let us know what it winds up being.
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 07-31-2007, 01:33 PM   #3
2005 34' Classic
Richmond , Virginia
If its a gear that is stripped is it hard to replace? Do you have to pull off the entire assembly? Geeze I hope not.
Old 07-31-2007, 01:52 PM   #4
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
I replaced the gears on my '89 Skyliner (Braund?) antenna - it was very easy to replace. As I recall, I just took off the access cover, reoved a pin and the gears came off. I lubed the new gears with high temp plumbing grease so the grease would't get runny in the hot summer days with the sun beating down. Antenna operated very smoothe since then.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 07-31-2007, 03:55 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Stripped Gears
Braund is correct. You can read the name on the base in the photo below. Good idea about the plumbing grease. I have been waving the bag with the new gears for mine at the handle, but that hasn't worked yet. I guess I will have to get on the roof afterall.
Vaughan
Name:	Nameplate 3a dark.jpg
Old 07-31-2007, 06:36 PM   #6
Central , Mississippi
On my SOB the gears came out from the bottom. Remove the crank and a pin and the fell right out. It's been a while and CRS may have fogged my memory but I'm pretty sure I didn't have to do it from the topside.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-02-2007, 09:16 AM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
Mine are definately on the top. They are just below the frame in this shot.
Vaughan
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Which Antenna ?? Jim Clark Audio, Video & TV 1 07-21-2002 06:32 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
