From the manual. LUBRICATION (Done 3-4 times annually)
STEP 1: To lubricate the elevating gear, apply a liberal amount of silicone spray lubricant to the elevating gear with the lift in the down position (see illustration). Run the lift up and down to distribute the lubricant over gears.
STEP 2: Two times yearly, or in the event rotating the antenna becomes dif cult, normal operation can be restored by lubricating the bearing surface between the rotating gear housing and the base plate. Any silicone lubricant spray may be used. Elevate antenna and remove plastic plug from rotating gear housing as shown. Spray lubricant into hole and around edges of gear housing. Rotate gear housing until lubricant coats bearing surfaces and antenna rotates freely.
All done on the roof.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
