Old 05-17-2009, 08:45 AM   #1
Montreal , Quebec
TV Antenna Info
I not too familiar with the broadcasting changes coming up, but will this make our antennas obsolete?
I' ve been trying to get info but its unclear to me.
Cary
wantostream is offline   Reply With Quote
Old 05-17-2009, 08:49 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
no.
antenna will still work; you'll just need to have either a digital receiver in your TV, or a converter box.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-17-2009, 09:16 AM   #3
dstalzer's Avatar
2005 25' Classic
I recently bought a new Toshiba 19" digital TV and get perfect reception with the original antenna. Just make sure you push the signal booster button on the wall antenna connection plate or you will get no signal.
dstalzer is offline   Reply With Quote
Old 05-17-2009, 09:34 AM   #4
Lily&Me's Avatar
Normal , Illinois
Same for us---replaced the TV rather than find a space for a box in our little buggy, works beautifully, antenna is still needed to help reception.
Old 05-17-2009, 09:40 AM   #5
Montreal , Quebec
So if understand well; a recent tv will still work fine with the antenna or I have to purchase that converter box.
Old 05-17-2009, 09:50 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
correct...if the "recent" tv has a digital tuner.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-17-2009, 09:59 AM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If your TV has a digital tuner it will pick up the digital signal. If it does not have a digital tuner, you will need a converter bos.
As far as your antenna, any antenna which picks up current UHF channels (those above channel 13) should work just fine. We have had a Visio TV in our '65 Caravel for over two years and have been enjoying digital, High Definition over the air TV using the antenna that originally came on our Caravel.
Note.......The numbering scheme for digital channels is slightly different. For instance, channel 2 analog will be on channel 2-1 on digital. Some channels have several new channels, like 4-1, 4-2, 4-3 etc.
Old 05-17-2009, 12:01 PM   #8
Montreal , Quebec
Thanks for your help, have a great sunday.
Cary
What is it: Antenna and? bmklawt Audio, Video & TV 3 12-18-2008 11:32 PM
FM Antenna info jimnsu Audio, Video & TV 0 10-18-2006 07:36 PM
Antenna JLD Electrical - Systems, Generators, Batteries & Solar 13 08-31-2006 08:41 PM
Best TV Antenna PossumTrotter Audio, Video & TV 2 10-13-2003 11:40 PM
Antenna Lee Pace Audio, Video & TV 3 09-21-2003 08:55 PM
