Old 07-22-2008, 11:12 PM   #1
GJ Excella's Avatar
1989 32' Excella
Grand Junction , Colorado
TV Antenna amp
The TV antenna in our 1989 Excella has not been used, that is the switch has not been turned so the light is on. When connected to a RV site site that has cable, I don't notice any difference from what I get at home, except for the digital. Do I need the amp?
GJ Excella is offline   Reply With Quote
Old 07-23-2008, 05:52 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You don't really need the amp, it is for boosting weak signals. generally, "on" is for watching tv off the air, and "off" is for watching cable.
Old 07-23-2008, 01:03 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
In other words, near a metro area you probably won't need the amplifier for the antenna; or, for some marginal stations, judicious antenna rotation and experimenting with the amp either on or off will sort out some weak signals. Away from metro areas it "may" allow some stations to come in.
Old 07-23-2008, 01:21 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
At home, we use an amplified antenna for the digital signal. Seems that digital does not get weak and fuzzy like analog. We either have it or we don't. There are some buildings in the way and the amplified antenna gets more digital station signals than without.
I would give it a try in your Airstream. Sure won't hurt. We don't have an amplified antenna in our Caravel.
Old 07-23-2008, 01:53 PM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I don't know if its the same type or not, by my "amplifier" also acts as an "a/b" switch. It doesn't just "amplify" the signal; it actually "connects" the signal to the coax port going to the tv. If its not turned "on", you get "nothing" on the tv. no signal. Being in the "off" position, it connects the coax port to the external cable tv connector.
There are 2 "inputs", and one "output". one of the inputs comes from the antenna; the other, from the external cable tv hookup. In the "off" position, the source is from the cable hookup; in the "on" position, its from the antenna...and that is "amplified". You can't choose to use the antenna, without amplification.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-23-2008, 04:58 PM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Mine works the same as Chucks. I have a another feed from the back of the coach, near the water and sewer for cable. I feed a cable back behind the fridge for my DirecTV sat dish.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Bad Cable from Power Amp to Winegard Roof Antenna tntom Audio, Video & TV 3 06-24-2008 08:09 PM
70's era Metal Ceiling Specs and R & R (Remove & Replace) Facts Distantdrummer General Interior Topics 3 06-22-2008 03:04 PM
Satellite radio antenna mounting & wiring silverback Electrical - Systems, Generators, Batteries & Solar 6 11-14-2004 06:24 PM
Curb Side & Front Glass Window & Clips Oceancontainer 1965 Safari 2 07-28-2003 07:04 PM
Antenna & Oven Difficulties Tamara General Repair Forum 13 07-30-2002 04:33 PM
