Old 11-23-2012, 09:48 PM   #1
jornvango's Avatar
TV antenna
Today after rotating the tv antenna from inside the Airstream ('95 Sovereign) to get some channels, the tv didn't find anything so I locked the antenna wheel in place and turned the handle to lower the antenna again.
A little later, as I stepped outside, I noticed that the antenna was still up. I turned the handle again but it didn't lower the antenna: it made the antenna turn ( which is usually accomplished by rotating the antenna wheel).
I climbed up the roof and found the connection between the antenna and the roof loose. I have no idea how this is supposed to be, but the only thing I did for now is to manually lower the antenna (while sitting on the roof), so tomorrow we can continue our drive. Hopefully the antenna doesn't fly of the roof.
Does this sound familiar to someone? Easy fix or did something likely brake in the antenna mounting system?
Thanks!
jornvango is offline   Reply With Quote
Old 11-24-2012, 07:12 AM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I'm assuming you have the Winegard antenna. Maybe this diagram will help. The crank is connected to 7 which is called the elevating shaft and there is a worm gear on the top end of this shaft. It engages 6, a plastic elevating gear. The elevating gear is visible from above. It is likely missing some teeth. This gear is relatively easy to replace and most RV stores carry it. They make it out of plastic in part so that it can function as a mechanical fuse, breaking before something harder to replace breaks. Winegard recommends spraying this assy with silicone lubricant twice a year to flush out any junk and to lubricate the gears. They also recommend removing a small plug to spray silicone lubricant between the rotating base parts. All this is done topside.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Winegard HA-0130 antenna... might buy Lothlorian Audio, Video & TV 3 03-10-2014 09:56 PM
Alternative TV antenna or bypass WineStream Audio, Video & TV 10 04-02-2012 06:48 AM
Roof crank up antenna wire goes where ??? dryenko Audio, Video & TV 10 01-17-2012 07:54 PM
Help with antenna location and setup dznf0g Phone, CB & Ham Radio 0 10-16-2011 08:46 PM
Radio antenna needed? SilverHoot Audio, Video & TV 25 01-19-2011 11:01 AM
