Old 05-06-2012, 10:38 AM   #1
1972 25' Tradewind
Midwest , Indiana
TV Antenna
Need to run coax for two TV jacks in a 1972 Tradewind. What is the best way to do this? There is not an antenna on top of the trailer (the base is there -- can I tie onto the wire that is in the base and run the coax? Thanks for your help.
reddog60 is offline   Reply With Quote
Old 05-06-2012, 11:07 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Consider an amplified Winegard Sensar with a add on for the higher frequency band stations. If you use the existing wiring you will need a 75 to 300 ohm transformer. It is very hard to fish a coaxial cable through the shell. I ran coaxial through the roof near the refrigerator vent.
Old 07-15-2012, 09:40 AM   #3
DFDureiko's Avatar
2004 34' Classic S/O
Brooksville , Florida
I have a '77 24ft RBT Argosy, with the same issue, the "head" of the antenna is there, but not the mast or the antenna..I though it looked easy enough to perhaps,,duct tape? the end of a coax onto the 300ohm wire and pull it thru? but your saying it's not as easy as that?? would the transformer work as good as a true coax?
Dan
DFDureiko is offline   Reply With Quote
