08-05-2019, 06:43 AM
2019 28' International
Murphy
Turn bathroom light on loose TV Signal
We have 2019 Int'l Signature 28 RBQ, if we have the TV on (using Ant) and turn on our bathroom light we loose the TV signal... things that make you go hmmmm.
08-05-2019, 07:00 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
On all channels or just one?
08-05-2019, 07:37 AM
Registered User
2016 25' Flying Cloud
Fairfield
There a thread here about this happening when the overhead LED lights are turned on, but I could not find it.
The reason I was looking, I just discovered last night if I run the LEDs on full it happens on the higher channels but all is fine when the lights are on the lowest setting.
Matti
08-05-2019, 08:34 AM
Tampa
I wonder if it shares power with the TV antenna booster? Either putting RF noise into the line, or somehow shorting the line.
Murphy
I loose all channels.
08-05-2019, 08:45 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
In all likelihood it is simply an RFI issue. The LED lights have a switching regulator in them. It produces interference. Depending on just how the wires are run and the minute construction details of this or that light ... you do or don't have a problem.
08-05-2019, 09:53 AM
Anywhere
, Alabama
Same thing happens to us when we turn on bathroom or shower fans
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
08-05-2019, 10:05 AM
2019 25' Flying Cloud
Hendersonville
, North Carolina
LED light interfearance
Both our 2017 23D (recently sold) and our 2019 FC 25 have the same issue. Great TV reception and many channels. Turn on the overhead LED's, and poof, no reception. We just consider it the nature of the beast. We have a nice small table lamp with a regular 40 watt bulb on the table that we use when watching regular TV. The LED lights do not effect anything when watching Netflix through a Fire Stick.
There may be some kind of cure for this condition, but we are not interested in rewiring the Airstream to get reception with the LED lights.
08-05-2019, 10:11 AM
2002 30' Classic S/O
Fleming Island
A filter designed to keep engine noise out of the car stereo might work to kill the interference at the light. The bad news is one would have to be installed at each interfering light.
Something like this might work (but it might not):
https://www.amazon.com/12-Volt-Noise.../dp/B00XKV114K
Depending on its design, it might work better on an interfering light if installed backwards. In the stereo application the noise is on the power line and the stereo line is clean. In the light application the noise is on the load side and you want the battery side clean.
Al
08-05-2019, 10:50 AM
2018 28' Tommy Bahama
Silver City
, New Mexico
Quick solution: Don't watch TV in the bathroom - except in the dark.
Class A Safari Trek 2830 - SOLD; TC Lance 1010 - SOLD;
TT Arctic Fox 30U - SOLD; TT Forest River Mini - SOLD;
Class B+ Pleasure Way Pursuit - FS; $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
08-05-2019, 11:45 AM
2016 28' International
Trois-Rivieres
, Quebec
Have the same TV signal problem when we charge a phone or pad with the USB charger upfront near the radio. Seems like the signal is very sensitive to any electromagnetic interference. But then, if it was like home, it wouldn't be glamping!
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
08-05-2019, 04:12 PM
2012 25' FB International
Baton Rouge
, Louisiana
You have a "loose" tv signal as in it's not tight? Or, did you "lose" the signal?
08-05-2019, 04:19 PM
Stay Calm and Stream On
2017 25' Flying Cloud
Palm Springs
2017 25a, Air TV works with lights on in bathroom, but scrambles when bathroom vent fan is turned on.
Stay Calm and Stream On!
08-05-2019, 05:58 PM
2008 27' Safari FB SE
Miami
Generally, the little DC motors in the vents are "dirty" in the sense that they put out all kinds of radio frequency interference (aforementioned RFI). Not much you can do about it.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
08-05-2019, 06:11 PM
Palm Springs
We make sure now to go to the bathroom before watching a good program...! Lol
08-05-2019, 11:00 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
I tapped into the power behind the antenna booster and I can tell you it's all kinda weird. I had to pull every fuse but still the little booster light was lit. Might be a hidden capacitor somewhere, or maybe wired direct to the battery (another phantom power draw?) but it was strange for sure.
08-05-2019, 11:18 PM
Spokane
I have heard that some folks who have retrofitted older trailers to LED lights have had similar issues. What follows is that these problems were often caused by the purchase of cheap LED lights that gave off lots of "noise" when in use.
But, this is a new trailer directly from Airstream and I am assuming that the owner has not changed out any bulbs. To think that this very expensive trailer will not allow you to watch television and have a ceiling light is preposterous. I would be at the dealer ASAP. If they say that it is just "the nature of the beast" I would then return with a television camera crew and a lawyer. This is totally unacceptable. Am I off base here?
08-06-2019, 05:13 AM
Sanibel
2019 FC 25FB when we turn on TV and suction fan in shower all channels get fuzzy.
08-06-2019, 08:34 AM
2019 30' Flying Cloud
Grass Lake
, Michigan
Does your bathroom light have a dimmer on it? LED dimmers use Pulse-Width Modulation (PWM) which essentially turns the power to the light off & on very rapidly (too fast for the eye to see). If not filtered properly that could cause interference, just like the cheap brush-type motors in the vent fans.
As a test: Try plugging the TV into a different outlet in the trailer, or better yet not through the trailer electrical system at all via an extension cord. If the problem goes away, it's a conducted emission problem that you may be able to get a filter to fix. If you still have the problem, it's likely a radiated noise issue which is much harder to fix.
08-07-2019, 05:16 AM
Murphy
I contacted Airstream Customer Service and the responded fairly quickly. However their response was concerning. The person responding indicated that they are aware that they are aware of the problem but have no fix for the situation. The person then asked if there was anything else they could help with. There was no indication that they were going to do anything to correct the issue going forward.
This is very concerning from a perspective that they are aware of a defective product but continue to sell it knowing this. You would think that this would violate the Consumers Protection Act.
If I sell my house, by law I have to disclose any defect that I am aware of, if not I could be sued and responsible of the cost of the repair.
