Old 06-26-2011, 04:17 PM   #1
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Troubleshooting TV cable
When I connect cable TV to my A/S via the little exterior connector next to the telephone connector at the left rear of the trailer I don't get a signal at the interior jack just above the refer. Has anyone had any experience troubleshooting this type of issue? Does the amplifier on button need to be off? Is the correct jack the same jack as the antenna jack? Thanks!
mhilley is offline   Reply With Quote
Old 06-26-2011, 05:56 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Amplifier off and the TV switched from antenna to cable usually thru the TV menu function.
Garry
Old 06-26-2011, 08:35 PM   #3
mhilley's Avatar
2000 23' Safari
Yes, you are correct, but if I get no cable signal to the TV it won't do me any good to go to the TV menu. Guess I wasn't too clear!
Old 06-28-2011, 08:30 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
To use cable reception you should be connecting the TV's cable to the satellite (or cable) "in" port...that connects the TV to the incoming connection (whether it's cable or satellite)... The roof-top antenna is not used when you are connected to cable (or satellite). The booster button can be off (unlit). (It's not needed).
Once you do have a signal you will probably have to program your TV for it though the menu.
Oh, the joys of technology!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Porter Cable Orbital vs Cyclo Becky B. Cleaning, Stripping & Polishing 30 06-23-2013 08:14 PM
Exterior TV Cable Outlet McDonalds Audio, Video & TV 3 06-13-2011 09:51 PM
Another Newb Question-Power Cable? jambie 2005 and newer - Bambi all models 1 03-08-2011 09:24 AM
Cable install.. JKnight General Appliance Topics 2 02-23-2011 06:10 PM
Breakaway cable length? oceantribe Brakes & Brake Controllers 12 01-10-2011 04:18 PM
