Old 04-01-2015, 01:03 PM   #29
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Terrible Reception
With ant in up position
Name:   ImageUploadedByAirstream Forums1427915007.134850.jpg
MICHAEL
Old 04-01-2015, 01:06 PM   #30
AWCHIEF's Avatar
Images: 33
In some locations I have doubled the number of stations I can receive after I swapped to the King Jack.
MICHAEL
Old 04-01-2015, 06:54 PM   #31
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Has anyone tried the new Winegard Rayzar yet?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-01-2015, 07:17 PM   #32
AWCHIEF's Avatar
Images: 33
Attachment 235378
Not sure what happened to the post. Should of posted a photo showing the antenna in the up position. Now I can not find it in my photo library. Also the recepeption is very good not terrible as my title came up.
MICHAEL
Old 04-01-2015, 07:44 PM   #33
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
For those confused, there are two models of the King Jack. One is the mast head which can be attached to the existing Winegard lift mechanism. It rotates using the same interior dial. The second model (8200) is a stationary exterior unit which requires the roof penetration to be enlarged to 2". The King Jack post extends through the roof and gets attached to a new knob in the new ceiling box which also houses the signal detector. You turn the knob and watch the signal strength bars illuminate to find the best direction. Once done, you then program your tv as before.
SeeMore is offline   Reply With Quote
Old 04-01-2015, 08:14 PM   #34
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Enlarging the hole
Originally Posted by lewster View Post
Sorry, phone has a mind of its own!!!!
I've placed 3 Jacks on new Airstreams. The existing hole for the flying saucer antenna needs to be enlarged to 2" and continued thru to the inner skin. No big deal really.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Lew:
Can you explain your method for properly enlarging the existing hole in the interior ceiling? Thank you.
Silverbee is offline   Reply With Quote
Old 04-01-2015, 08:26 PM   #35
Durango , Colorado
Originally Posted by Msmoto View Post
My plans, after reading up on the King Jack antenna are to install it myself. Having done multiple other mods to the Serenity, I see no issue with this one.
As to the suggestion about pointing the antenna properly, the one supplied with the 2015 Airstreams has no adjustment being "omnidirectional " or as the saying goes, "a jack of all trades, master of none". And this is with the booster on. Booster off = nothing on my set.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
If you decide to update, please document your installation procedure , either with video or pictures. I know I would be interested in seeing how it goes and I am sure there are others.
My one concern was how well this was going to work now that there is a larger compartment in the roof for the ducted air.
So far I haven't had much trouble with the omni-directional antenna as it seems to be pulling in a lot stations in the areas that I have camped.
One thing for sure, a message to the original poster, " Do make sure to turn on the booster behind the main TV, it makes a big difference".
RVDreamer is offline   Reply With Quote
Old 04-01-2015, 08:37 PM   #36
Durango , Colorado
Hey, that looks great! It sounds like this might eliminate the need to cut a hole through to the interior of the new 2015s.
Thanks for the info. Now we just need to find out if it works well.
Old 04-01-2015, 09:01 PM   #37
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
King Jack Antenna Installation
This will be completed within the month, hopefully. But, as one of those who purchased a 2015 Airstream long before the Classic was even announced, I am busy trying to catch up on interior mods so i have more "Classic" features, specifically window valences ....... so, these are first, the antenna second.
I will do some photos of the install once I begin. I think as Lew has suggested it is fairly straight forward, as long as one understands how to use a hole saw on aluminum....very carefully.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 04-01-2015, 10:26 PM   #38
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
I really appreciate all of the information about the King Jack but it really didn't answer my original question. Does anyone make a portable type of antenna that can be attached to the satellite connection on the outside of the Airstream? I watch very little television but would like to have it when needed. I have no desire to have a hole cut in top of my Airstream.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 04-01-2015, 10:34 PM   #39
Durango , Colorado
You might look into that Winegard Rayzar automatic antenna. It looks to have better reception specs than the King Jack antenna and it would not require a hole into the interior. The antenna is contained in a small dome and electronically rotates and finds the best orientations for signal reception.
Looks like a simple install. In fact, if 3m VHB tape was used, I doubt that any holes would need to be drilled or sealed.
Old 04-01-2015, 10:43 PM   #40
Durango , Colorado
I don't think you could use the satellite connection because it routes to the Blu-ray player compartment, with the idea that you will use a satellite receiver there and then connect to the tv's via HDMI cables.
You also would not have a power amplifier on the line. If you connected to the cable input, it might work but again you would not have a signal amplifier on that line.
There are numerous antennas you could hook up via coax on the outside but I am just not sure it would work with those inputs.
When you were getting poor reception with the omni-directional antenna, did you have the signal amplifier turned on? It makes a huge difference. The button to turn it on is behind the main tv, right next to the cable connection, it has a green led lit when it is on.
Old 04-02-2015, 04:42 AM   #41
r carl's Avatar
Lin , Ne
When I bought my King Jack I chose a black one because I think it looks better on aluminum. I wish they had an aluminum colored one though.
Old 04-02-2015, 05:26 AM   #42
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Silverbee View Post
Lew:
2" hole saw with the pilot drill just slightly behind the existing coax hole..........
Terrible Mold Everywhere piccio General Interior Topics 8 03-01-2004 06:33 AM
Wireless Web Reception niftypkg General Interior Topics 1 11-08-2002 08:03 PM
