Old 10-15-2014, 04:18 PM   #29
wscampo's Avatar
My trailer is fairly remote and I was mistaken about having AAA batteries. Therefore, I will be prepared to check that next trip before bringing the tv in for replacement.
wscampo is offline   Reply With Quote
Old 10-15-2014, 04:19 PM   #30
wscampo's Avatar
Originally Posted by AnnArborBob View Post
If you've got power to the television (aka TV ) and the red light is on, then there is no point to check the breakers. Did you solve the mystery yet? Dead remote batteries?
Thanks again, I will report back.
Old 10-15-2014, 04:55 PM   #31
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
We have a 46" Samsung in our brick-and-mortar house. I had a similar "power on" problem, and it turned out to be some bad capacitors. I found a repair guy on Angie's List who repaired it for something like $100.00. You can Google the issue of Samsung TV's and capacitors and find out how to do the repair yourself. The bad caps are pretty easy to spot, bulging, etc. If you have good soldering skills you can probably do this yourself. I think this is a known Samsung issue.
Cannonball is offline   Reply With Quote
Old 10-15-2014, 05:30 PM   #32
wscampo's Avatar
Thanks. I am starting to think that is a good possibility. The trailer is fairly late model and in think the tv is original (2010). Also the Sony DVD and radio is connected and looks like original factory installation so I was trying to be sure it was not a mode selection issue.
Old 10-15-2014, 05:37 PM   #33
2011 23' FB Flying Cloud
2008 19' Safari SE
Brossard , Quebec
On my 2011 Flying Cloud 23FB, I experience a such similar issue.
In a normal situation: If you "turn on" your TV (either with the remote or with the on/off "front button") the "power on" sequence should be: 4 LED blinks (3 to 4 seconds period) after that time: image and sound.
Fail situation: Same "turn on" command, but the front red LED is always blinking and no sound either image. The "power up" sequence is not successful.
When this situation occur, I read on the internet that these Samsung TV suffer of a known problem: "leaking" cheap capacitor by premature aging. My TV was "born" in late 2010 according to the manufacturer label sick on the back.
In the internet they suggest to "heat" the back of the TV lower left corner near the AC line cord is plug (where the power supply is located) with a hair dryer for about 1 minute or 2. Surprise image and sound appear!
I bring my TV at home open it (screw at back) and visually check for bad capacitors (busted ends) and all of them seems OK.
I notice that a flat ribbon cable plug between the power supply board and the TV board was not fully engage into his socket. Push it in place and since that time "no power" on failure.
Hope this help.
Michel
Papou is offline   Reply With Quote
Old 10-15-2014, 07:22 PM   #34
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by richw46 View Post
If you have a red light on the TV and you cannot get to the TV menu, then your issue is with the TV. I had one go out just like that; only the red light, couldn't get anything to work. I think you need to head to Best Buy for a replacement unless you want to spend $$$ for TV repair. If it's large you might want to consider a repair shop, otherwise, it's cheaper to replace it.
Yes, that was our conclusion, too, when we replaced the smaller with a larger on our 2012 ... known bad issues with the Samsung. They seem to age whether turned on or not!
Old 10-16-2014, 03:29 PM   #35
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Glad I have a 2007 Samsung. They used to make them better in the old days.
Snarky is a cool word, but what is better than Hetch Hetchy? I like tecolote, but that's Spanish (owl).
Gene
Gene
Old 10-22-2014, 05:54 PM   #36
wscampo's Avatar
Originally Posted by TinTin View Post
I think idroba might have it!!
This worked. I suppose the switch on the tv is out of order. I can now turn it on from the remote with fresh batteries. Thank you.
Old 10-22-2014, 06:33 PM   #37
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Take it out for a nice candle lit dinner, then a few drinks, then back out to the camper for a nightcap. Give it a good back rub. Gaze longingly into its flat screen... That'll turn it on.
O, just keep pushing buttons until it gives in...
Sorry, been wanting to do that since I first read the topic...
-Red, TV love doctor...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-22-2014, 10:38 PM   #38
1974 Argosy 20
Kooskia , Idaho
Oh boy, I won the prize! Made a lucky guess, I guess.
Seriously, sometimes the simple things are easy to overlook. Who remembers that the remote even has batteries, they work for years with one set.
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 04:37 PM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
Water Pump will not turn on AccessMaster Water Heaters, Filters & Pumps 2 12-07-2003 02:08 PM
