Old 10-14-2014, 01:07 PM   #15
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Originally Posted by Hoobiedoobie View Post
I automatically think tow vehicle on this site! Any where else I think television!! 😃
Not Ru Paul?
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 10-14-2014, 01:53 PM   #16
2015 27' FB International
mesquite , Texas
being old and feeble and unturned to the present world and knowing there is no such a thing as a stupid question what the heck is a snark
moxie t. moto is offline   Reply With Quote
Old 10-14-2014, 02:19 PM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Sarcasm without the sarcastic tone.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-14-2014, 02:54 PM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Most of us.
When you turn on a Samsung, the red light blinks and then the set comes on. The TV plays one bar of music. There is no green light on the newer ones. Go through the menu and check for antenna or cable and select whatever is appropriate for you. Check also that the TV speakers are turned on unless you have it attached to the trailer speakers. For sound through the trailer speakers, you have to turn on the radio and it will find the TV setting (except it hasn't worked for years on ours except for DVD's so I just use the TV speakers for TV programming).
On the one in our trailer, there are 2 places to attach the cable—one for antenna and one for cable. I got some short pieces of coaxial cable and screwed each into the two antenna/cable inputs, attached a splitter to them and them screwed that into the trailer system. That was you don't have to switch the trailer cable every time you have a different input. The trailer system may be screwed into the cable system rather than the external antenna on the roof. That could be your problem.
If there is no red light on the set, check the breakers.
Gene
Gene
Old 10-14-2014, 03:33 PM   #19
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Another definition:
snarky ... grouchy
snark ... grouch
A common condition among 60+ males (PCE)
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-14-2014, 03:36 PM   #20
Master of Universe
Gene's Avatar
Originally Posted by TinTin View Post
Another definition:
snarky ... grouchy
snark ... grouch
I've been snarky for 14 years and love it. It is a welcome part of being a senior citizen. Now get off my grass! Oh, I don't have any grass—I live in a desert. Get off my tumbleweed!
Gene
Gene
Old 10-14-2014, 03:46 PM   #21
TinTin's Avatar
Canmore , Alberta
Working on it myself!!
Bob and Nancy
Old 10-14-2014, 04:31 PM   #22
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Snarky is an ill-appreciated art form.
arktos55343 is offline   Reply With Quote
Old 10-14-2014, 05:12 PM   #23
time2play's Avatar
2013 30' Classic
Kent , Washington
TV could mean anything.....tunnel vision, terminal velocity, technical view, travel voucher, tricuspid valve, threshold voltage, time variance, Tualatin Valley (in Oregon)...
Yes, I visited the acronym site. I can't believe how many definitions there were for TV.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 10-14-2014, 07:42 PM   #24
wscampo's Avatar
Originally Posted by Gene View Post
Most of us.
Gene
Thank you. So far all I have is a red light indicating power. It goes off when I unplug it. I will check breakers, radio connection, etc.
wscampo is offline   Reply With Quote
Old 10-14-2014, 08:39 PM   #25
Hoobiedoobie's Avatar
1987 25' Sovereign
Chilhowie , Virginia
I actually like being a bit snarky. I also enjoy saying the word. Snarky. 😝
Hoobiedoobie is offline   Reply With Quote
Old 10-15-2014, 08:33 AM   #26
richw46's Avatar
Lexington , Kentucky
If you have a red light on the TV and you cannot get to the TV menu, then your issue is with the TV. I had one go out just like that; only the red light, couldn't get anything to work. I think you need to head to Best Buy for a replacement unless you want to spend $$$ for TV repair. If it's large you might want to consider a repair shop, otherwise, it's cheaper to replace it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-15-2014, 02:45 PM   #27
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
The small frame around our TV unsnaps on the road and the Samsung will not turn on until I snap the boarder or small surrounding trim back on. Our original TV was replaced under warranty and this does the same thing now.
subfan1 is offline   Reply With Quote
Old 10-15-2014, 03:21 PM   #28
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
If you've got power to the television (aka TV ) and the red light is on, then there is no point to check the breakers. Did you solve the mystery yet? Dead remote batteries?
Bob Martel
WBCCI# 5766
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 04:37 PM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
Water Pump will not turn on AccessMaster Water Heaters, Filters & Pumps 2 12-07-2003 02:08 PM
