Old 11-11-2006, 08:24 AM   #15
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Wires
I have not tried to locate them yet.When I was doing a trade in for this one I talk to the tech guys about it and they told me that they were usually behind the wall where the fridge is.He told me that taking the fridge out is fairly easy but I think it was the part of pulling it out took a little time.Unscrewing and such was fast.
I would like to take this task on now but I just feel I need to get some diagrams to do this because I can not really remember which wires and screws I am suposed to remove from the outside compartment for the fridge.It has been a while.Well it looks like another new project is born.It would be great to have this hooked up I am wanting to upgrade the sound system a bit
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 11-11-2006, 10:01 AM   #16
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I noticed some screws that seem to hold the fridge in from the outside. I'm sure there are also mounting areas inside too...just haven't looked too closely. I agree, sounds like a neat project to try. Maybe one day.
As for the stereo, that one is beyond easy. Add a sub? The power wires, RCA connectors, etc are all in the streetside sofa storage. I got a bazooka BTA6100, which is a powered 100watt sub. Too big for the streetside sofa storage, plus, I liked using that space for flashlights, etc. So I placed the sub in the enclosed area under the front sofa. Wires were plenty long and then I wired a remote bass control for the sub so that I could adjust if if I wanted. Works great...not too gangbanger like, not too tame, but clearly better than the standard Sony offering. Want even more bass? The 8100 has it, but might not fit under the area I'm talkin' about. The 6100 just fit, with less than a hair to spare.
The rest of the audio system is a piece of cake to replace if one wanted. All wiring is done, just would need to pop in different components and if need be expand the holes if the gear one bought was bigger.
Old 11-11-2006, 10:08 AM   #17
Devoman's Avatar
Fridge
That is what they showed me were those screws in the front of the fridge also.You take the plastic strips off then unbolt I think 2 wires in the back and a few screws to unmount the fridge and it slides out but that is where you have to be patient.I am thinking I am going to call Airstream today and ask them If they have a diagram for doing this.I dont think I ever seen it in the manual.
Old 11-11-2006, 10:17 AM   #18
Devoman's Avatar
E-mailed
I just e-mailed Airstream to see if they could help some.If they can not I will call my dealship down south to see if they can show me how to take out the fridge to get to those wires.
Old 11-11-2006, 11:24 AM   #19
CanoeStream's Avatar
St. Cloud , Minnesota
john hd & I got together last month. We discussed his fridge repair. Due to the extreme tightness with the bulkhead, John had a heckuva time pulling his fridge out -- it gave a little, they lubed with LPS spray and pushed it in and out with more lube before it finally came. He advised that I better not use a hollow wall anchor if I consider mounting anything up against the fridge. So that sounds like another vote for pulling the fridge if you wish to anchor anywhere but over the top of the fridge.
5 meter Langford Nahanni
Old 11-11-2006, 11:43 AM   #20
Cstar's Avatar
2006 28' Safari SE
Columbus , Ohio
Images: 20
Silvertwinkle
No photos for a few days, still haven't taken delivery. The mount is an OmniMount U2 Fixed (medium, supports up to 80 lbs.) I will take some pictures later and try to post them.
Here is a view from OmniMounts web page. http://www.omnimount.com The verticle supports attach to the mounts on the TV and they inturn 'hang' on the two horizontal round bars on the fixed wall mount. They also have a tab that is moved into position to lock the attachment so that an inadvertant bump won't cause your expensive flat panet to fall from the wall.
Corky
Cstar is offline   Reply With Quote
Old 11-13-2006, 12:17 PM   #21
Devoman's Avatar
Fridge
Airstream was not able to get a diagram to show me.Mabey it is policy.That is ok though.I will figure it out one day.I just wished there was a tech on the forums that might have done this type of project to let us know exactly where that RCA wire runs.Have to call a dealer and check if they will be kind enough to let me know for sure.
Old 11-13-2006, 12:51 PM   #22
Mookie's Avatar
1992 21' Sovereign
Oakland , California
Images: 60
Audio/Video
Finished installation of a Sirius subwoofer last weekend. It just fits under the sofa and behind the drawer. Makes a huge difference in the sound. Spent a lot of time this weekend analyzing the situation with the wall next to the frige. I've decided to opt not to remove the refrigerator. There is a 1" hard insulation panel between the back of the wall and the refrigerator. I'm going to fabricate a 3/16" aluminum plate, similar to the Airstream mounting plate, but much larger and beefier, and mount it to the wall with mollies.
-Mark
Mookie is offline   Reply With Quote
Old 11-13-2006, 01:10 PM   #23
Devoman's Avatar
Hey
Sounds good.I will be studying up on the fridge some to see what I can do in the future for this RCA delema.I really want to hook up the Flat screen to the stereo but I dont want to reroute some new wire.I am going to keep looking for a solution.Beside that I need to get a really good stereo deck anyways.I want all the bells and whistles on the next one.I say the easier the betterWith a remote that is.
Old 11-13-2006, 01:21 PM   #24
Devoman's Avatar
Better Sound
You know that Airstream only set the speakers within the cabinets.A very easy and simple install.One thing they do not do is make it sound better.These speakers that they put in here are very good companies and are very good speakers.The thing to do is go to your nearest stereo shop and ask for the foam backing for them.I am pretty sure some of you know what I am talking about but for those who dont.Here is what it looks like.The sound quality of your music will become a lot better.Trust me they work.
http://www.crutchfield.com/S-L8zgDTp...sp?g=762&avf=N
Old 11-13-2006, 01:42 PM   #25
Mookie's Avatar
1992 21' Sovereign
Images: 60
Originally Posted by Devoman
...The thing to do is go to your nearest stereo shop and ask for the foam backing for them. The sound quality of your music will become a lot better. Trust me they work.
Hey Devoman - I agree - I used these foam backing cups when I upgraded our system - they make a big difference.
-Mark
Old 11-13-2006, 01:48 PM   #26
Devoman's Avatar
Speakers
When they placed the speakers in there spot there is nothing back there to seal it so air escapes everywhere.Plus the opening in side the cabinet is to big so the sound quality is distorted to where you can not here certain sounds.I love listening to good quality music.My cars have them but now it is the Airstreams turn for an upgrade.
Old 11-13-2006, 02:25 PM   #27
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
If you look near the end of the 2005 Classic 28 thread, you will see the reinforcement that I made for my microwave cabinet to mount my flat panel TV on the side. I made a wood reinforcement that spanned the 3/4" square blocks at top and bottom. I also inserted additional screws in the 3/4" blocks into the top and floor of the compartment.
I think that a taller version of my reinforcement would work in a refrigerator cabinet.
John W. Irwin
WBCCI #9632
Old 11-13-2006, 03:03 PM   #28
John -- From your 22' CCD days I save links or have bookmarked all your home improvement threads! Here is the applicable page on his 28' Classic thread.
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
awning bracket manley Awnings 2 08-22-2002 06:16 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
