Old 08-28-2006, 06:12 AM   #1
1977 31' Sovereign
Erie , Pennsylvania
Television Mounting
Good morning all.
I'm getting ready for the next trip and I was wondering what you guys have done to secure your televisions. I have a regular 20" that can be seen in the link below.
http://www.airforums.com/photo...0&userid=14384
I have a strap that goes around the back and through the shelf, but I'm afraid that if I hit a big bump it will put it up over the lip on the shelf and the strap will slide down and off to the floor it goes...any suggestions. I don't really want to have to put it on the floor when I tow it around.
jrk247 is offline   Reply With Quote
Old 08-28-2006, 09:36 AM   #2
Frank S
peoria , Illinois
Hi jrk274--We use our TV in the same position as your picts show, but find the low tech way of placing it on the floor against the gaucho still the easiest, safest way to travel.--Frank S
Frank S is offline   Reply With Quote
Old 08-28-2006, 10:41 AM   #3
1971 29' Ambassador
Leonardtown , Maryland
Tv
We have gone to LCD TVs. They are much lighter and easiely placed on the floor. They also move around easiely if you wish to watch TV outside with friends over.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 08-28-2006, 11:07 AM   #4
RobertC's Avatar
1970 21' Globetrotter
Pickens , South Carolina
I've been wondering the same thing about mounting. Also, the LCD tv's, can they be mounted directly to the wall?
Skip Callaham
2003 Volkswagon Jetta TDI (yes, it's a diesel!)
2001 Suzuki Esteem
1976 Triumph Spitfire 1500
1973 Triumph Spitfire 1500
1971 Mercedes Benz 220D
1965 Triumph Spitfire MKII
(Yeah I know, Too many cars!)
RobertC is offline   Reply With Quote
Old 08-28-2006, 11:14 AM   #5
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
If your strap is wide enough, you can get velcro and attach to the strap and sides of the TV so it can't slide down or you could attach a hook to the wall behind the TV and wrap a bungie cord around the TV to keep it away from the edge. Both are easy to remove and inexpensive.
We went LCD and bought the backer plate and Omni arm that Airstream uses and the Velcro strap wouldn't vit arount our TV so we went the bungie route to hold the TV against the studs on the backer plate.
Family of Disney Fanatics
WBCCI# 4821
Old 08-28-2006, 03:41 PM   #6
1977 31' Sovereign
Erie , Pennsylvania
I hadn't thought of putting a strap across the front to hold it. I think that will work great. I don't want to go buy an LCD for it when I already have a new tv that wasn't in use anywhere else that fits in there perfectly. When this one breaks that will be it's replacement.
Have a good night
Jake
Honda Generator Mounting dmac Our Community 24 07-17-2016 09:46 PM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 03:55 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 06:03 PM
