Old 05-12-2014, 11:37 AM   #1
1974 Argosy 20
Kooskia , Idaho
Television mount adjustments
The television mount in my 2014 FC 20 has been stiff and unpleasant to move around. Since you are grasping the television itself, it is possible to break it. In addition, I had not found a swivel to allow it to be tilted. Last trip out I looked at it in detail.
The pin which holds the mount slides into a very tight fitting hole. I finally wound up taking a rat tail file and enlarging the hole slightly. See photos 1 and 2. The frame was very stiff and I found that I could adjust the tension on it, making it easier to move. You need to be careful, it can get sloppy fast. See photo 1 again. There is a tilt function, yea! There is a pin on a ring which can be pulled out and the entire television will tilt downwards. See photos 3 and 4. For storage, tilt back up and replace the pin and ring.
I also noted that the power supply on the Samsung television supplied in my rig is a 14 volt one, so any of you who are adventuresome might want to try to see if it would work on 12 volts. I have not done that and probably will not. See photo 2 and you can note the wire showing a 14 volt supply.
I hope these ideas will make the television more useful to you.
ID:	211764   Click image for larger version
ID:	211766   Click image for larger version
Old 05-14-2014, 07:06 PM   #2
LucaBluPlus2's Avatar
2014 25' FB Flying Cloud
Rochester , Minnesota
Idroba, you just made my day!
Picked up our 2014 25fb FC a few days ago and are having trouble with the bedroom tv mount. We cannot get it to pull out and extend the arm. At all.
Is it just that sticky? Is there a locked position?
Even our sales guy was unable to help. Can you?
Anyone else have this problem?
-Carrie
If I only had a dollar for every time I got distracted, I wish I had a puppy.
LucaBluPlus2 is offline   Reply With Quote
Old 05-14-2014, 07:11 PM   #3
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
We just picked up a 2014?25fb Int. and I was unable to extend the tv arm. I've been busy getting everything ready for camping I completely forgot to research this issue until I saw this thread.
Landrum is offline   Reply With Quote
Old 05-14-2014, 09:06 PM   #4
Exactly Landrum, I am in the same boat.
Anyone have any guidance on this? Tricks to get the BR TV mount unstuck?
As always, thank you.
-Carrie
Old 05-14-2014, 09:33 PM   #5
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Try pulling down the strap. It releases a spring loaded button. It should move quite easily after that. You wouldn't want it to move too easily though. Being a bit stiff is good.
GAStreamin is offline   Reply With Quote
Old 05-16-2014, 04:52 PM   #6
1974 Argosy 20
Kooskia , Idaho
Yes, pull on the strap, but it may be very very hard to get it loose. It is a real PITA. Be careful you don't break the TV while pulling on it to get it to move. Miserable thing to get out. But don't make it too loose either. It will flop around then. I had to adjust it several times to get it just right. And, you may have to file the hole on the lock button as I did as it is just too damn close fitting.
Old 05-17-2014, 11:26 AM   #7
Hmmmmm, I seriously do not see a strap. Landrum, did you get yours unstuck?
-Carrie
Old 05-17-2014, 11:41 AM   #8
1974 Argosy 20
Kooskia , Idaho
In the upper left photo of the original post there is a gold grommet which is attached to the pin and to a strap below. Does yours have that? It is below my hand holding the wrench.
Old 05-17-2014, 11:56 AM   #9
Landrum's Avatar
I'm going to go look right now
Old 05-17-2014, 12:02 PM   #10
Landrum's Avatar
Okay I finally got it. There is a strap that is attached to a locking pin. You have to pull down very very hard to pull the pin down.Click image for larger version
Name:	ImageUploadedByAirstream Forums1400349758.284995.jpg
Old 05-18-2014, 11:00 AM   #11
Yeah! Found the strap, it was a little bound up. Worked liked a charm, thank you!
-Carrie
Old 01-29-2015, 11:36 AM   #12
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
Does anyone know the brand and/or model of this TV mount. I'd like to add a bedroom TV to my FC 20 with this same mount. Also, I'd like any advice as to attaching the mount to the wooden wall vs. the outside wall of the trailer.
Glenn T.
Glenn T is offline   Reply With Quote
Old 01-29-2015, 03:18 PM   #13
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up LCD storage
Just what I do....
LCD--- LIQUID, (as in freezing), Crystal Display
I called Samsung and asked for the limits for "do not operate in extreme temp variations" that was given in OP manual. They were unable to pin it down.
So as a result,
Here in WNY.....I bring our Samsung inside during storage.
Old 01-29-2015, 03:28 PM   #14
ottawa (greely) , Ontario
Yes you can run the t.v on 12.8 volts from your airstream battery ,I'm in the process of getting a plug that fits the t.v. ,its a really weird plug with a center pin ! I have seen this plug on some sony Bluetooth speakers, still looking for it!
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Equalizer hitch adjustments Raptorrider2001 Hitches, Couplers & Balls 4 09-22-2017 10:45 AM
30 ft. Classic Limited pocket door adjustments patrick p General Interior Topics 9 05-25-2012 04:12 PM
results of CAT Scales and WD hitch adjustments funkill Hitches, Couplers & Balls 10 07-11-2009 06:35 PM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
Tappan Oven adjustments srgntpepper Stoves, Ovens & Microwaves 0 12-07-2003 06:15 PM
