Old 10-20-2007, 07:08 AM   #1
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Television hook up to speakers
Can anyone advise how to connect television speakers (RCA plugs out) to the installed speaker system in the 2007 Safari-20ft?
Silverbee is offline   Reply With Quote
Old 10-20-2007, 08:08 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The RCA outputs are not speaker level, they are line level outputs in most cases. They are designed to be used to connect to receivers, or in your case, the aux input on your coach stereo.
Many of the outputs on tv's can be switched to be either constant or variable. When switched ot constant, the level is always the same, volume control must be done via the stereo.
When variable, then you can conrol the volume via the TV, since it varies the feed to the stereo. You just leave the stereo at a medium volume setting.
You may have to purchase a specialty connection kit of sorts, depending on your individual case.
Uwe
www.area63productions.com
Old 10-20-2007, 10:00 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
It is quite likely that you have wires in the wall for this. What AV package did you get?
Michelle TAC MT-0
Sarah, Snowball
Old 10-20-2007, 11:40 AM   #4
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
Did your unit come with the audio/video upgrade?
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 10-20-2007, 12:07 PM   #5
Silverbee's Avatar
2007 20' Safari SE
Just have the AM/FM/CD/MP3 Player with four ceiling mount speakers. Then added the wall mount for flat screen tv. No A/V upgrade for that.
Old 10-20-2007, 12:18 PM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Silverbee, If your AM/FM/CD/MP3 Player has an RCA Aux. input you can run the TV through that. Or get a little amp to power the wall mount speakers. More info about the TV and AM/FM/CD/MP3 Player would help. Model number and features.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-20-2007, 10:31 PM   #7
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
I tried to have the TV wire plug to the RCA input and it doesn't work. From the player manual it seems that an optional device need to be added in between the wire and the player.
to find the source... It's a Sony player but don't know which one
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 10-21-2007, 06:30 AM   #8
Zugbug's Avatar
Volcano , California
Its likely that the A/V jacks you plugged into are for a CD changer, I don't think these will work for the TV, I believe they also need a control circuit connected. I have the newer model Sony and I am planning to replace it with a unit that has an AUX input just for this purpose.
Zugbug
2006 23' Safari
2006 F-150
Zugbug is offline   Reply With Quote
Old 10-21-2007, 10:02 AM   #9
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
do you know what model it is
TAC# : QC-1
my blog
Old 10-22-2007, 05:42 PM   #10
Zugbug's Avatar
The model I have is the CDX-F5000 and this unit does not have an AUX input only inputs for a multiple CD changer. To conect my TV/DVD I am going to replace this unit with one that has an AUX input. Anyone have a recommendation?
Zugbug
2006 23' Safari
2006 F-150
Old 10-22-2007, 05:46 PM   #11
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Go to Parts Express - Amplifiers, Head Units, Speakers, Wiring Kits, Subwoofers, Dampening
They have very good solutions for mobile 12V powered video.
Uwe
Old 10-22-2007, 05:52 PM   #12
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
You can probably use an antenna modulator that goes in line to your antenna input. Your TV line outs plug into this. Then, you can tune to a certain FM station, and play the TV sound through the radio section. The sound quality will not be quite as crisp as a direct aux input, but it's not so bad that it's unbearable. TV sound often isn't that good anyways, due to the maximum compression the TV enginners use.
I am not talking about the FM that receives through teh antenna, I am referring to the hardwired FM system. Many use this to connect their ipods to car stereos.
Uwe
Got speakers? KHarris Audio, Video & TV 7 06-14-2010 06:13 PM
Speakers Safari Tim Audio, Video & TV 15 04-18-2007 02:03 PM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
rear speakers ALANSD General Motorhome Topics 4 01-25-2003 03:33 PM
Stereo Speakers kntd Audio, Video & TV 4 01-20-2003 06:37 PM
