Old 04-29-2010, 09:57 AM   #1
Davadar's Avatar
2005 19' Safari
2010 30' Flying Cloud
Langton , Ontario
Television for 19' Safari
We are picking up our new to us 2005 19' Safari next week. We are wondering what size of tv would fit ? Any suggestions ?
Dave
Davadar is offline   Reply With Quote
Old 04-29-2010, 10:03 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Our son in Tampa has a 2006 19' Bambi. He uses a 19" flat screen which he stores on the bed while underway. Our 2005 25FB came with a 15". We have already gone to a 19". I have already done some measuring, and I believe a 22" would work.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 04-29-2010, 10:06 AM   #3
Chasmorgan's Avatar
1999 23' Safari
We have a 23' Safari 1999 and chose a 22" LG in HD. It works very well. Anthing smaller (we tried a 19") is too small and anything larger is too big to take down and store when we move in our opinion.
Chasmorgan is offline   Reply With Quote
Old 04-29-2010, 10:06 AM   #4
Johnco's Avatar
2006 19' Safari
Anaheim , California
Although we don't use it much, we just put a 19" led-lcd into our bambi and it fits nicely. The advantage to the led-lcd is the reduced thickness and weight (not to mention the lower power consumption).
Johnco is offline   Reply With Quote
Old 04-29-2010, 10:16 AM   #5
Davadar's Avatar
2005 19' Safari
Langton , Ontario
Brian
Hi Brian
Does your son have his tv mounted to the wall, I have not seen a bracket that is easy to detach. Can the tv be left on the wall while travelling?
Dave
Old 04-29-2010, 10:22 AM   #6
moosetags's Avatar
Originally Posted by Davadar View Post
Hi Brian
Dave
Our son just puts his on the counter by the door on its factory stand. He secures it on the bed for travel.
Brian
Old 04-29-2010, 10:42 AM   #7
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Several years ago we modified the fridges side cupboard in our Bambi to allow the mounting of a 13" LCD TV inside the cupboard and on a swing out bracket. We did look at other options but wanted to maintain all the counter space on top of the fridge and neither did we want to compromise any other interior space.
The upside of this configuation is that it does not compromise any interior space at all, is very easy to stow, can be watched as in the picture - or can swing out into the space between the fridge and the galley. This location for the TV allows for very comfortable viewing from the dinette in terms of distance and eye-height.
The downside is the space limitation on the TV size - I believe there is enough room for a 15" but that is something to be checked - we chose 13" simply because that is what was available, we knew it would fit, and it was on sale at the time.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 05-02-2010, 12:12 AM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have a 15" television in my trailer and we are OK with it's size. It's just for camping so I don't need a monster sized screen. But the newer models are about the same physical size and come with 19" or 20" screens. If this one goes bad, I will replace it with 19" or 20" model of the same size case.
Name:	IMG_0337 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-02-2010, 07:26 AM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
We have an LG 22" HD LCD, and it's about the same size as the 19". I got a hinged base with an easily removable mount. It swivels and extends for viewing, and I remove the TV when we travel. The bracket that holds the TV in place is held on by a single wing nut, and goes on and off easily. I got the mount on Ebay for about $20.
Toyota 4runner and 19' safari bebelee Tow Vehicles 5 02-14-2009 02:49 PM
Second Television in 25 Safari SE FB Hyperion Audio, Video & TV 5 11-17-2008 09:25 AM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
19' Bambi or 22' Safari? The Duck 2005 and newer - Bambi all models 6 07-09-2005 08:27 PM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
