Old 08-05-2015, 03:40 PM   #15
Racheli's Avatar
2013 27' FB International
Casper , Wyoming
On the Sony press "source" to get CD, then press "mode" to get CD2.
Then write it down, because it makes no sense and you will forget how to do it, like I do.
Diabolical, absolutely makes no sense.
Thank you. I tried it but still doesn't work. When I press CD 2 it says "no magazine". Any other tips? Thanks for your help with this diabolical sound system!
Racheli is offline   Reply With Quote
Old 08-07-2015, 11:06 AM   #16
1974 Argosy 20
Kooskia , Idaho
I just tried it again and on mine, even though it says "no magazine" on CD2, with the television on (not on mute BTW) and the DVD player providing the signal (no off air reception here) I get the television sound through the diabolical Sony.
So, all I can tell you is that mine works that way. You may need to raise the television volume, not sure if that might help.
I have never, ever, seen a more difficult and non intuitive system. I am very glad I almost never watch Television.
Old 08-07-2015, 03:08 PM   #17
Racheli's Avatar
Casper , Wyoming
Okay I'll try that! Thanks again!
Old 08-08-2015, 08:54 PM   #18
Racheli's Avatar
Casper , Wyoming
Guess what?? I got it working! The cord from the TV was plugged into the wrong outlet. I changed it to the audio out..I tried this once before but this time I jiggled the cord and it worked. I kept it on CD 2,
Yay so happy! Too bad it's almost end of our camping season. Thanks again!
Rachel
Old 08-16-2015, 12:30 AM   #19
Bend , Oregon
Ditto that
derf is offline   Reply With Quote
12 volt
HItch ball height via AS and via Leveling mefly2 Hitches, Couplers & Balls 5 03-13-2012 01:56 PM
Should Television work on battery power alone? yakman Audio, Video & TV 15 07-25-2009 01:51 PM
12v Television or Inverter cameront120 Audio, Video & TV 18 04-21-2008 11:16 AM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
