Old 03-19-2010, 10:24 AM   #1
rustyrivet's Avatar
2005 22' Safari
Gresham , Oregon
Swift Hitch Camera and Monitor Problem
About six weeks ago I bought a Swift Hitch camera system from Hensley to help with the solo hook-up process. When I received the camera, I tested it at home to make sure it worked; the picture was fine. A couple of weeks ago we went out for our first trip of the year. I hooked up the Swift Hitch camera and again it worked fine......until I started the tow vehicle. When the engine started, the picture on the screen was totally destroyed by some kind of interference. I spoke to Hensley,and they referred me to the manufacturer, Two Loons. I e-mailed Two Loons and they indicated that they thought the problem was probably some after-market attachment I installed on the tow vehicle. Other than the trailer brake controller, there aren't any aftermarket attachments. The vehicle is new (5400 miles). The Blue tooth system is built in and was turned off during the test of the camera system. Has anyone else bought one of these camera systems and had a problem with it? jc
2005 22 ft Safari LS
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
rustyrivet is offline   Reply With Quote
Old 03-19-2010, 11:14 AM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
ours is a year old, and have had no problem to speak of in a 2008 F150, though the picture is marginally clearer when the engine is off, and when the monitor is up on the dashboard rather than lower on the seat...
try the camera in another vehicle to see if it's your vehicle affecting it or not?
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 03-19-2010, 12:47 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
On on my turd one, two replaced by two loons, spends more time in the glove box than anywhere else.
Found a VR3 system on ebay for $89 wired into the running lamps so it can be used while towing, permanent mount, works fine.
The same view with both camera's....you decide.
POI..after awhile you'll get used to the haha and be using the camera less & less, I do use the VR3 to check on things while towing though.
Name:	CAMERA TEST 028.jpg
ID:	98374   Click image for larger version
Name:	CAMERA TEST 031.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-19-2010, 08:02 PM   #4
2005 22' Safari
Gresham , Oregon
best,[/QUOTE]
Good idea, will try that.
sempi2 is offline   Reply With Quote
Old 10-28-2014, 08:59 PM   #5
Roselle , New Jersey
Swift Hitch New 2015 Digital
It was not the one bad camera the analog cannot have any obstructions, and are affected by some transmissions. The digital has no interference.
I have the NEW swift hitch 2015 digital camera & monitor in stock for 319.00 free shipping. This unit goes through walls, vans, good signal always. This is available
Website link is Swift Hitch Trailer Camera - Cargo Trailer NJ
Rockyboy is offline   Reply With Quote
Old 10-28-2014, 10:07 PM   #6
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I have an older Swift Hitch and have never had any issues.
LilNomad
LiLNomad is offline   Reply With Quote
Rear Monitor & Camera Advice spat61 General Motorhome Topics 12 12-26-2009 07:16 AM
Safety Camera/LCD Monitor Muddy Waters Audio, Video & TV 8 01-25-2009 11:43 AM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 04:10 PM
AS Hitch problem AirBud Hitches, Couplers & Balls 15 11-20-2006 09:22 AM
Backup Camera monitor Save$$$ GlenCoombe Classic Motorhomes 8 08-08-2005 02:49 PM
