Old 08-18-2012, 07:58 AM   #1
2005 28' International CCD
Aurora , Colorado
standard TV reception is "line of sight", right?
Hey we just inherited this 2005 International. Previous owner never used the TV. So after buying a converter box to handle the digital conversion, we fired it up foe the first time last night. The thing scanned for signals and couldn't find one.
Since TV frequencies are uhf or BHG, I'm assuming that the reason we can't pull in a channel is because we are camping behind a huge ridge that is blocking the signals from the local TV stations? Or maybe we aw just too far? Denver is 90 miles south, Cheyenne is 30 miles north, but ft Collins is just about 10 miles away but I'm not even sure they have a local station.
So could it be just that I'm not close enough or blocked and my standard antenna just isn't capable of pulling in a signal?
Thanks. Seems Luke a simple question butbthought o would ask anyway in casebtjwre is something I'm not thinking of. U have neverbowned a TV that needed a conversion from analog to digital and I just wanted to bounce this off of the forum.
Chris
k0irl is offline   Reply With Quote
Old 08-18-2012, 08:03 AM   #2
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
TV reception
Did you turn the amplifier on? If not push the little button on the faceplate where the TV antenna attaches to the wall. Green light should come on. Now try to scan again.
fltlevel510 is offline   Reply With Quote
Old 08-18-2012, 08:04 AM   #3
Aurora , Colorado
And excuse my blackberry's auto type mistakes. I took my reading glasses off too soon and then hit send...
Old 08-18-2012, 08:05 AM   #4
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Go to www.dtv.gov/ and go to maps. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 08-18-2012, 12:38 PM   #5
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
As long ago as the 1940s, we were receiving television from Lancaster, PA some 40 miles away and across several sizable mountains. At 10 miles around Cheyenne, you should definitely get a decent signal.
I suspect that the amplifier (green light) was off on the plate where you plug in the TV. If the green light is off, the circuits think you are hooked to cable and disable the antenna.
John W. Irwin
WBCCI #9632
Old 08-18-2012, 12:40 PM   #6
Aurora , Colorado
@fltlevel510: thanks. No such button on or around the crank that raises and rotates my antenna. I agree an amp would probably give the antenna some gain. So I'm assuming by that advice, you're in agreement that everything is ok and its just a matter of signal strength from the transmission source?
@noreen: thanks. I'll check that site out.
Old 08-18-2012, 12:47 PM   #7
Pahaska's Avatar
Hays County , Texas
The green light and associated button are on the plate that the TV signal cable screws into, not where the elevating crank is.
John W. Irwin
WBCCI #9632
Old 08-18-2012, 01:06 PM   #8
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Where are you?
Ken
Old 08-18-2012, 01:12 PM   #9
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Chris,
If you are at a campground, see what direction other RV antennas are facing. You should be able to get the one channel in Ft. Collins and whatever is in Cheyenne. The antenna probably would face differently for Cheyenne. it should be perpendicular to the direction the signal is coming from.
HDTV signals are harder to get than SD signals, so the range is less. There is also available an add on for the antenna that is supposed to be better for HD signals—it costs around $20.
Have you tried the TV with a DVD to see if it works?
Gene
Old 08-18-2012, 01:25 PM   #10
Ag&Au's Avatar
Here are the things you are up against.
Since the whole system has never been used, locating the problem will be a PITA.
Because of the nature of digital signal process, you will not be able to detect a week signal. With analog TV, a weak signal produces a fuzzy picture. With digital it looks like a blank screen.
I assume that since those distances you cited don't describe Aurora, that you are camping somewhere east or west of Ft Collins.
Finding out what the problem is will be very tedious unless you are are in a place where you know there will be good reception, Aurora for instance.
It would be nice if you could borrow a digital capable TV and keep the converter out of the circuit until you can get a picture on the TV.
As far as the antenna goes, it should receive digitals signals if there are any to receive.
Ken
Old 08-18-2012, 01:49 PM   #11
Aurora , Colorado
@fltlevel510 and pahaska. Found the green light. It was on a cable plate under thedining table. Thanks to you both. I have 21 or so channels. Have a great day!
Old 08-18-2012, 01:54 PM   #12
Ag&Au's Avatar
Congratulations,
Even though it means I wasted all that great advice.
Ken
Old 08-18-2012, 02:30 PM   #13
Master of Universe
Gene's Avatar
How many are worth watching?
Gene
Old 08-18-2012, 02:49 PM   #14
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
It's the number not the quality, sort of like. the journey not the destination.;-)
