Old 05-09-2005, 12:59 AM   #1
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Spring has Sprung (or Antenna Repair)
Spring has Sprung in Michigan - Finally!
I got a sunburn on the roof of the '85 Sovereign today - really. First from washing it in the sun, then from replacing the gears in the Braund Antenna. I got the "gear kit" from Mark's RV. One gear was slightly different than the original, but it went together just fine. My big problem was trying to figure out how to get it apart without instructions, but I eventually worked it out - it just took a little longer than expected. Now it raises and lowers and turns just fine. Anyway, I just wanted to share my success story to counterbalance my other post about our water tank leak.
To those with the same antenna that has quit going up and down, this can be a "do it yourself" repair as long as you don't mind getting up on the roof - you'll never do it leaning over from a ladder. Just remember to put those stabilizers down, or it'll get shaky up on the roof. And remember to keep your foot steps on the roof ribs, not between them.
Joe
WBCCI/VAC #6768
66Overlander is online now   Reply With Quote
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
Airabelle has sprung her door jeanarlene 1969 - 1973 Safari 12 02-06-2011 12:09 PM
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
