Old 06-19-2016, 11:22 AM   #1
2016 30' Classic
Santa Rosa , California
Speaker problem
We intermittently lose the signal on the right OR the left Polk speaker while watching TV and using the Polk AUX setting to direct sound to the Polk speakers. While watching, the signal dynamically swaps between going to both sides, one side, or the other side - several times per hour.
Any thoughts on cause?
phann is offline   Reply With Quote
Old 06-19-2016, 11:52 PM   #2
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Would start with the audio connections at the tv and at Polk unit by inserting / unplugging and wiggling ends when connected and tv playing. (If you can make it do same errors, clean, lubricate connectors with Corrosion X or WD40 and repeat. Trying a new set of wires/connectors may do it.
If issues persist, check the various audio settings on tv as the dynamic sound options (theater, surround, etc.) can mess with a stereo input.
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Speaker Switch & Speaker Replacement vswingfield Audio, Video & TV 17 10-01-2011 05:48 PM
New speaker placement TomW General Interior Topics 13 04-22-2005 05:44 PM
Speaker Wiring For New Stereo j54mark Electrical - Systems, Generators, Batteries & Solar 8 04-13-2004 09:26 AM
Speaker grille removal in 2000 Excella Cracker Audio, Video & TV 8 04-12-2004 06:54 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
