Old 09-12-2013, 09:22 PM   #1
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Hey all,
Just put a car receiver/cd player in my 1969 ambassador. Three out of the 4 speakers work! But they don't sound so great. After 40 years of sitting around I'm surprised they work at all. The back speakers are 4x6s and I think all stick with that. But the front speakers are set in the fiberglass end cap. It's pretty large opening so I could fit a 5x7, 6.75" round, and I might be able to wiggle in a 4x10. I don't know for sound quality what would be best, so I'm looking for ideas.. What have others done in the past?
Not all those who wonder are lost.
Silverflames is offline   Reply With Quote
Old 09-12-2013, 10:19 PM   #2
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
I put kicker speakers in mine, they sound great. Alpine is the way to go but they can be pricey.
If the back speakers are wall mount measure carefully as you don't have a lot of depth to work with.
kevinb is offline   Reply With Quote
Old 09-13-2013, 05:51 PM   #3
1969 29' Ambassador
Kevin,
Any thoughts about these?
Kicker DS693 6" x 9" (152 x 229mm) 3-Way Speakers (Pair of Speakers)
They have them at Walmart $75.
Old 09-13-2013, 06:00 PM   #4
johnamjr's Avatar
1970 25' Tradewind
parkville , Maryland
Polk audio 5x7 db or dxi series sound great. Just make sure you seal up around the speakers.
johnamjr is offline   Reply With Quote
Old 09-13-2013, 06:11 PM   #5
1969 29' Ambassador
Sorry to be ignorant, but why seal around the speaker?
Old 09-13-2013, 06:49 PM   #6
johnamjr's Avatar
1970 25' Tradewind
Speakers especially car speakers need a sealed enclosure to produce full range sound. I had to make a cut out to fit the speaker into the rectangular opening. An use rubber foam seal to between the speaker and the housing. And seal the housing an the speaker plate I had to cut out. I don't recommend the 6x9 3 ways they are too bright of a speaker and the will need more power to sound good. My 5x7's have plenty of bass an good full range sound. They would not have any bass if I did jot seal them up.
Old 09-13-2013, 07:01 PM   #7
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Originally Posted by Silverflames View Post
Kevin,
As long as they will fit in your application they should sound great.
Old 09-13-2013, 07:03 PM   #8
1969 29' Ambassador
Would sealing them into the end cap be enough, or should I build a small box to put the in, and the slide the box into the end cap?
The stereo puts out up to 45 watts per leg. Don't know if that would be enough for a 6x9.
Old 09-13-2013, 07:18 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ignorance may be bliss,, but the original speakers in my 70s trailers still sound good to me.
Old 09-13-2013, 07:33 PM   #10
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Mine just went in the endcap, right where the originals were. That will act as an enclosure in its own right.
That output should be plenty, see what the speakers are rated for.
Old 09-13-2013, 07:36 PM   #11
1969 29' Ambassador
I was really surprised it find that they worked at all, but if you turn up sound they sound garbled. I figure the cones are shot.
Old 09-13-2013, 08:52 PM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Sealing speakers doesn't matter so much on mids and highs, but makes a difference in low bass response.
Just having them bolted down improves the sound tremendously.
The rubber gasket already attached to the basket is a good enough seal.
The new trailers have good sound systems.
Sony car stereo, (2) 6 1/2" coaxials in the front, (2) 6 1/2" coaxials in the back, and a SAS 8" powered sub under the couch.
iPod, bluetooth, Blu-ray, and everything.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is offline   Reply With Quote
