Old 07-17-2016, 02:41 PM   #1
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Sony stereo Model DSX-S301BTX does not see iPod or any internal device
Quick tip here , if you have a device like an iPod player in your Sony stereo system and it does not see it.
Try this; remove the device and shut down your system, disconnect the power (put the battery switch to store mode). This will kill all power to the coach. Then reconnect power (shore or otherwise). The stereo will reboot. Reinstall your device and cycle through the different sources and it will see your device now.
BTW it may work on other systems where your device isn't recognized by your stereo system.
Laurence
LAWBC is offline   Reply With Quote
Old 07-19-2016, 05:42 PM   #2
TJS
Highlands Ranch , Colorado
How play audio CDs? through the stereo system
2014 Airstream Flying Cloud 25 FB Twin
How can we play audio CDs in our new (to us) Airstream -- through the stereo speakers, not through the TV? The Sony Digital Media Player DSX-S310BTX doesn't have a CD player. Is there a way to connect a portable CD player to the USB port such that we can play the audiobooks we like to check out from the library? I see that Sony does have an adapter No. XA50-WM for connecting a Walkman to a USB. Will this work? If so, which Walkman CD player(s) would be compatible?
Tried playing them on the Samsung Bluetooth DVD player but nothing happens. Also, we do not want to have to leave the TV turned on just to listen to a CD -- running down the batteries unnecessarily.
Please advise. Thanks.
thomasjstone is offline   Reply With Quote
Old 07-20-2016, 10:47 AM   #3
LAWBC's Avatar
Your head unit should have a USB port on the right side, it has a slide gate that opens to a USB port. I see that it is the same model number..
Laurence
Old 07-21-2016, 03:00 PM   #4
TJS
USB Port for portable CD Player
Yes, these units do have two USB ports, one external and one inside the drawer ("tune tray"). The question was whether we could connect a portable CD payer through one of the USB ports and if so would it work? This because there is no AUX MP3 (3.5 mm) input on the Sony unit (amazingly).
Old 07-22-2016, 11:10 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Does your trailer have the Samsung Blu-ray player?
Play the CD in the Blu-ray player and then select input CD-2 on the Sony head unit.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-22-2016, 02:54 PM   #6
shadedsilver
2014 27' FB International
Bisbee , Arizona
This correct for using the TV through the stereo system also..Sony has to be set to CD2.
shadedsilver is offline   Reply With Quote
Old 07-22-2016, 11:15 PM   #7
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
[M. Honey] &
well OK now. this is news. I'll give it a try. Aside from the bulk issue and the fact I can jam about 180 albums on the Walkman, we've been leaving the CD's at home because we didn't like playing them thru the TV. To be honest it never occurred to me that it would be a stereo setting....the whole TV/BR stereo IMO is challenging....and I'm just trying to get some tunes on. I thought I was doing well just figuring how to make to "go dark" i.e. loose the default light show.
I've been playing with the Walkman mp3 vs three separate thumb drives (rock, jazz and Hawaiian) trying to find the easiest solution to scrolling, folder vs album as well as continuous play.
CruizinDux is offline   Reply With Quote
Old 07-23-2016, 03:30 AM   #8
m.hony's Avatar
2013 30' Classic
Maybe now it will be less challenging?
It's kinda sorta like an old school home stereo component set.
Big ole amp or receiver, several tape decks, turntable, EQ, tuner if you had an amp rather than a receiver. Receiver is just the amp and tuner
Then as time passed CD player, VCR, stereo TV, DVD player-
Always had to select your source on the amp or receiver-
Always had to select "Tape 1" or "Tape 2" depending on if you were listening or recording-
I still have a hodge lodge of old school and new school components hooked up to my surround sound receiver from tape deck and turntable to Blu-ray and Wii console.
There is even a complicated way within the Sony (fader) to mimic the "Speakers A, Speakers B, Speakers A and B" of an old school home amp/receiver.
Some folks maybe never had a big home stereo system?
Everything now is influenced by Windows.
All selections made via menus-
TAC #MS-10
Airforums #70955
Old 07-23-2016, 08:54 AM   #9
CruizinDux's Avatar
I hope so. thanks for the tip. I'll check it out.
Old 07-23-2016, 04:09 PM   #10
TJS
CD through the DVD player
I think I mentioned that we couldn't get the CD to play through the DVD player with the TV on. We were only given the "CD" option as the input, not "CD 2". In any event, even if it had worked, when we are dry camping without electricity we do not want to leave the TV on. Any other suggestions?
Old 07-23-2016, 04:42 PM   #11
m.hony's Avatar
2013 30' Classic
There is another button you push after you get it to CD to select CD 2.
I would have to be in the trailer to tell you.
We're going on a trip Friday.
I'll jog my memory.
TAC #MS-10
Airforums #70955
Old 07-23-2016, 04:59 PM   #12
CruizinDux's Avatar
thomasjstone, as for the CD in the BR, I remember it being a big technical challenge and to be honest can't remember specifics. I'll re-read the instructions to jog my memory but since I don't have SP at storage it will be awhile to physically walk thru it.
When I discovered that the TV needed to be on and music played thru the TV I received a 16 GB Walkman NWZ-E385 for my birthday. I jammed 180 albums and headed for San Diego on our maiden voyage. The first way I figured it out was to use the Walkman USB connection...connected it at the slide drawer...jammed it all in and used the Sony to navigate thru the music. It was later on the trip that I figured out that I could use the exterior USB port instead of the slide drawer. Much better and I could use the WM functions to navigate.
Once I was this far, I figured USB is USB so I loaded an album on my key chain flashdrive. Presto. Now I use the WM in the car and the flashdrives in the Sony. I have all my music on my laptop so it is easy to swap out albums...drag and drop for the drives and WM
Here are my getting the music going notes plus a few others. It's a work in progress.
However the manual after you re-read it a bunch of times while standing at the Sony, it starts to makes sense.
Old 07-23-2016, 07:49 PM   #13
CruizinDux's Avatar
thomasjstone, since these electronics at least to me are difficult, I pulled out the manuals for a refresher.
Looking at the BR manual (which BTW has a tag line...imagine the possibilities....for sure, I'm trying. ) there is a section on navigation pg9 of my manual. For the BR remote there is a HOME button at the top, that when pressed opens a menu for to select "Videos, Pics, Music and settings" Maybe try music or videos as appropriate. Seems his was my first threshold.
Also I noticed in the front panel drawing pg6 that there is a USB host behind a little flip face plate. maybe a DVD player could be hooked up there...maybe even a Mp3/flash drive. I've never tried.
as for
...We were only given the "CD" option as the input, not "CD 2".
on the sony note #2 of my sheet sheet press source/off repeatedly until you find CD, then press mode to set that CD...seems once there you can press source/off repeatedly to scroll thru the CD options (1,2). Also try Q to scroll thru the CD options. If you're using a Walkman for music select external (if appropriate).
Obviously if you're dry camping and assuming there is no inverter/genset to provide 110, the BR is out of the picture.
Hope this helps.
Old 07-23-2016, 08:22 PM   #14
m.hony's Avatar
2013 30' Classic
There ya go.
That's what I was trying to remember.
Press "Source" till you get to CD.
Then press "Mode" to get to CD2.
TAC #MS-10
Airforums #70955
Best device (not list) for tracking DO-DONE travel-related tasks? InterBlog Sprinter and B-van Forum 32 04-08-2017 09:41 AM
Does anybody need an original 1978 Motorola stereo with 8 track? drboyd Audio, Video & TV 12 03-02-2016 08:39 PM
Replace stereo w iPod. Suggestions? NJtoNC General Interior Topics 6 10-14-2013 05:12 AM
Playing iPOD through stereo sweetsilver Electronics & Connectivity 11 05-14-2011 10:31 PM
Adding a 12V stereo (iPod ready?) to vintage AS Stella Audio, Video & TV 15 04-22-2008 05:30 PM
