Old 09-03-2007, 09:40 AM   #1
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Sony Radio Reception
I own a 2006 Safari LS 23 footer. The Sony radio plays CD's flawlessly and the sound is great. AM and FM reception in town is the BEST.
Drive out of an urban environment I have poor or no reception. Yes. I have played with the local on/off and stereo mono and maybe I should put some tin foil on the antenna? My car radio will receive a station and I will run the number onto the Airstream radio and it may or may not be a strong enough signal. I have been using a portable radio outside the trailer and come in and see if the Sony will be able to receive the signal. Most likely, not.
Has anyone tried add a taller antenna. If so, where can I get one? I camp in locations that are high and clear of obstacles, but expect a better option with AM reception at night and it would be nice to avoid going up and down the frequency hoping something turns up.
Ray Eklund is offline   Reply With Quote
Old 09-03-2007, 09:47 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have that problem now, our antenna is bad. Have you checked to see if yours is plugged in?
Old 09-03-2007, 09:57 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Not sure how your antenna mounts - ours is a ball mount on the side. Replaced it with an antenna from Advance Auto Parts with an AM boster coil on the shaft - kinda of a copper looking coil. It works great. I'm sitting in a low area but able to pick up AM at night from St. Louis, NY, Richmond, Atlanta, etc.
Old 09-03-2007, 11:12 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Excellent point
Originally Posted by Ganglin
Not sure how your antenna mounts ...
Gary raised an excellent point. I might have some information to share, but its usefulness depends on where the antenna is mounted.
Where does Airstream put antennas nowadays?
Tom
Old 09-03-2007, 12:45 PM   #5
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
New trailers have the antennas top and center forward of the first roof fan. They are a foot long whip type antenna.
Ray, my recpetion is poor with my Sony as well.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 09-03-2007, 01:00 PM   #6
TomW's Avatar
1967 26' Overlander
RF is NOT my strong suit
Originally Posted by Westfalia
... They are a foot long whip type antenna. ...
A ham radio operator can fill in the blanks, but the optimum length for an FM radio antenna is 29.92 inches. And, the antenna needs to be perpendicular to a reflector for best reception. The higher the 29.92 inches is, the better.
Airstream skin counts as a reflector.
Tom
Old 09-03-2007, 01:50 PM   #7
emdubyadee's Avatar
2007 27' Safari FB SE
Pottsboro , Texas
I have the same issues, Ray. In addition to weak reception, I often have a lot of interference which isn't present in my pickup radio. When camping in a relatively remote area, I often can not receive any stations at all on AM or FM. In the city it works just fine.
It would be great to discover an easy fix to this issue.
emdubyadee is offline   Reply With Quote
Old 09-03-2007, 02:04 PM   #8
brownsmtnlab's Avatar
1970 31' Sovereign
Greeneville , Tennessee
Images: 8
It may just be your radio...We have 3 fairly new automotive/marine 12 volt radios, and of the 3 the sony has the worst long range reception..We have a Pyle marine/weather band am/fm in our Airstream and its the best of the 3. The pioneer is the next best....But the old original AM radio in our 78 datsun pickup is far superior for long range AM reception than any of the new digitally tuned recievers.
If you don't know where you're going, any road will take you there
brownsmtnlab is offline   Reply With Quote
Old 09-03-2007, 02:10 PM   #9
Ray Eklund's Avatar
The antenna is located, as earlier described correctly, up front behind the vent on top. It is about 12 inches tall, maybe a bit less. The antenna appears to screw on, like the one I found on the road last month... I don't think I need the 6 foot whip on top (my CB days), but maybe a car antenna will work.
My portable radio will not work inside as the Airstream does keep any signals from getting through the walls. Our cell phone does not have that problem, though. Sure is nice for local weather reports and news. Now I use a week old newspaper and make up next weeks' forecast.
Old 09-03-2007, 04:00 PM   #10
Well Preserved
1993 21' Sovereign
I installed a new antenna this afternoon. If yours unscrews from the base, you can get a mast from an auto parts store for about $5, and screw it onto the base. I put ours on the side of our coach, it is easier to extend and retract there. You can get one that you can partially lay down so it will be the 30" or so that Tom suggests without being 13' in the air.
Old 09-03-2007, 05:28 PM   #11
jzelle's Avatar
2006 28' Safari SE
Halifax , Nova Scotia, CANADA
Our Sony's reception is dismal as well. Ergonomics on the Sony is also the worst I have ever seen on a consumer product.
However, since I installed a satelite radio the Sony's lousy reception is no longer an issue.
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
jzelle is offline   Reply With Quote
Old 09-04-2007, 08:21 AM   #12
Zugbug's Avatar
Volcano , California
And I thought my antenna was disconnected, I checked and it is not. Now I see I am not alone with this problem. Does anyone know of an antenna that I can just screw into the same connection as the existing one?
Zugbug
Zugbug
2006 23' Safari
2006 F-150
Zugbug is offline   Reply With Quote
Old 09-04-2007, 10:28 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Radio Reception / Check your Mast.
Hi, When I first bought my trailer, my antenna was loose. Before I got it home the antenna was laying on the roof. There is a half ball type joint near the base of the antenna. Half the ball is on the roof mount and half the ball is on the mast; And it is joined together with an allen head bolt. I wondered why and how it got loose until one day I tied to turn my television antenna without raising it all the way up. The television antenna pushed the radio antenna over causing the allen bolt to come loose. Now everytime I travel to a new location I have to re-read the operator's manual to set my radio for best local reception. My radio seems to work well after doing this, But for the rest of you with the same type antenna that I have, I would recommend going onto the roof with a set of allen wrenches and makeing sure the mast is tight. [loose mast = poor reception]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-04-2007, 11:24 PM   #14
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
ROBERTSUNRUS - Thanks. I will check that.
Just to confirm is your radio also a Sony?
jd
JDL is offline   Reply With Quote
WIFI reception Devoman Computers, Internet & Satellite 34 10-08-2007 07:56 AM
TV reception niss1679 Electrical - Systems, Generators, Batteries & Solar 21 09-11-2005 05:22 AM
sony radio/CD player dhe9 1997 - 2004 Bambi 1 11-13-2004 07:22 PM
lack t v reception.... norbert Our Community 1 09-02-2003 09:05 AM
Wireless Web Reception niftypkg General Interior Topics 1 11-08-2002 08:03 PM
