Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 06-24-2008, 07:17 AM   #1
ubelt
Profile:  1972 27' Overlander
Columbus , Ohio
Sony Power Problems
I have a 72 and just put in a new sony with ipod hook up. Everytime I switch on a light or the AC kicks on the sterio resets itself. (turns off then back on) I could see the voltage changing when the AC turns on, but a light? Are there surge protectors I could put inline of the 12V power to the radio? Thoughts?
ubelt is offline   Reply With Quote
Old 06-24-2008, 07:26 AM   #2
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i had that and found a bad connection in the 12v breaker box. wiggle some wires, that's how i found it. the lights would get dimmer/brighter when i touched the 12v feed at the buss bar.
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
welcome to the collective
Old 06-24-2008, 07:37 AM   #3
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
What circuit is the sony wired to? Is it the same circuit as the lights? It sounds like a bad ground on the 12VDC side of the converter
Old 06-24-2008, 08:03 AM   #4
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
I've had the exact same symptom, and I figured it was just voltage fluctuations from the old univolt, and newer solid state car stereos require "cleaner" power. It only happens when on battery power. doesn't happen on shore power.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 06-26-2008, 12:20 PM   #5
ubelt
Columbus , Ohio
thanks for all of your input. i'm heading up this weekend and i'll let you all know what happens. thanks again!
Have you replaced your Sony radio? Kistler Audio, Video & TV 8 12-23-2007 04:46 PM
Sony Radio Reception Ray Eklund Audio, Video & TV 20 10-12-2007 05:54 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
sony radio/CD player dhe9 1999 - 2004 Bambi 1 11-13-2004 07:22 PM
Power Jack Problems Daniel Conroy Electrical - Systems, Generators, Batteries & Solar 4 04-15-2004 10:40 PM
