Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 05-24-2009, 12:49 PM   #1
silverback's Avatar
Profile:  2006 28' Safari SE
1981 28' Airstream 280
Phoenix , Arizona
Sony MEX-R5 head unit causing WiFi interference
I haven't seen this posted before and apologies in advance if that is the case. Anyhow we discovered a "feature" of our Sony head unit that I didn't know about. It has a factory default setting that is turned on to transmit audio and video over FM in the 2.4 GHZ band (2414 for channel 1). That's just fine but that also happens to be very close to the WiFi channel 1 frequency (2412). Close enough to block the WiFi (G) channel 1. We had another WiFi access point available on channel 10 (2457) that worked fine. So we spent quite a while troubleshooting our connectivity to the Airstream park WiFi and concluded that it was an interference problem. But we had no clue what was causing it. I just happened to completely turn off the radio and notice that I could then connect to the park WiFi. RTFM time. And sure enough the manual fully documented the wireless AV capabiliy (warned of interference) and and described how to turn it off. It can use 4 different channels but I chose off as we're not using it. And the WiFi worked perfectly as soon as I changed the setting. I wanted to pass this along in case other people were banging their heads troubleshooting. And I'm sure other Sony units have this same "feature".
-KL
4CU Charter Member
1981 Excella 280 Turbo Diesel Motorhome
silverback is offline   Reply With Quote
Old 05-24-2009, 01:24 PM   #2
Profile:  2009 23' FB Flying Cloud
Anywhere & , Everywhere
Ran into this myself about a year and a half ago at the KOA in Perry, FL. Fortunately one of the work campers there was familiar with the problem and we got it straightened out. Now I wish someone would tell me why I cannot get connected to the Airstream Outside WiFi at Jackson Center. My stereo is completely turned off so that is not the problem this time.
Al - K4GLU is offline   Reply With Quote
Want To Replace Stereo Head Unit DEITZ645 Audio, Video & TV 1 03-07-2009 06:31 PM
Tires Causing Sway? Pick Tires 14 12-03-2006 04:38 PM
Sony MEX-R5 Multi Disk Player - Tip ostream Audio, Video & TV 0 07-26-2006 09:06 AM
Fix pilot assbly, replace unit, or shower head instant HW? kdenault Water Heaters, Filters & Pumps 1 07-24-2006 08:28 PM
Hitch Interference Camp-Dog Hitches 14 12-13-2004 03:56 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
