Old 10-17-2018, 08:23 AM   #1
2018 23' International
Minneapolis , Minnesota
(simple) Antenna Question
Hi all,
I have a 2018 AS. The over-the-air antenna works just as it is supposed to. For travelling it will be just fine.
I have just purchased a lot at the Minnesota Airstream Park, which is about 70 miles away from Minneapolis/St. Paul. The built in antenna barely picks up the Twin Cities signal. I would like to add a stationary pole mounted antenna with greater range.
Is it as simple as just running the coax from the auxiliary antenna into the "cable" input on my Airstream?
-John
Gopher John is offline   Reply With Quote
Old 10-17-2018, 08:33 AM   #2
kpm
2018 25' International
Mound , Minnesota
Yes, I believe that will work, although that route will bypass the built-in antenna amplifier. If you want one for the external antenna you will have to supply your own. You might also try asking your Airstream park neighbors what they've done regarding specific antennas, mounting, etc. No telling what you might find out
kpm is online now   Reply With Quote
Old 10-17-2018, 08:41 AM   #3
Thanks KPM. I don't think I'll need a signal amplifier if I get a good "directional" outdoor antenna - since all of the channels are coming from the same general direction.
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 04:23 PM
"Have dish, will travel"? Need your input on a simple mounting for satellite antenna Aage Audio, Video & TV 13 10-30-2009 09:34 PM
Simple electrical question about Batt. and charger jasoncase Electrical - Systems, Generators, Batteries & Solar 7 07-18-2009 10:25 AM
Simple question about low voltage dis panel schematic? Mrcrowley Batteries, Univolts, Converters & Inverters 10 08-18-2008 08:25 PM
Simple question, maybe. Jim & Susan Tires 9 07-31-2008 07:35 PM
