07-19-2009, 07:40 PM
2007 25' International CCD FB
Gahanna
Should Television work on battery power alone?
I was looking at my television today to get an idea of what to replace it with and noticed it reads 18 V DC on it. (would like to get HD tuner tv so I don't have to deal with the converter box anymore)
Should my tv be able to work under battery power only? It never has so I assume no. If it is, something must be wrong.
The TV is the Sony 19" that came with the trailer.
yakman
07-19-2009, 07:54 PM
1968 28' Ambassador
Cedaredge
I don't think they do, and if it did your batteries wouldn't last very long..
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-19-2009, 08:02 PM
1993 34' Excella
Estancia
I tried Akai and Audiovox 12v tv/dvd player units. The DVD drives did not last in the 12v units. I now have a Sharp TV/ DVD that I use with a 400w modified sine wave inverter. I have a 200 amp hour Universal AGM battery. This weekend in addition to the interior lights and water pump my grandson watched at least 8 hours of DVDs. The battery still had plenty of juice.
07-19-2009, 08:54 PM
2005 31' Classic
Gretna
, Nebraska
My TV runs on 110V that is converted to 12 V. I called the company and asked if I could cut off the plug and transformer and plug it in to 12 V power. He did not like the idea even a little bit.
Using the inverter as mentioned above would be the way to go. I have 2 AGM's as well and think I could go for a little bit. Mostly news & weather is all I watch anyway.
Dwight
07-19-2009, 09:06 PM
1958 26' Overlander
Mesa
yakman
Only if you have an inverter that converts 12vdc to 110ac.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
07-19-2009, 09:19 PM
2006 19' Safari SE
Tucson
We have to use our factory inverter to run the TV or DVD via the TV...but it doesn't seem to wear down the batteries much.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
07-19-2009, 10:15 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
I have a Magnavox HD Tv in my trailer which I bought because it runs on 18V. The 110 AC plug that came with it is a large converter plug. I bought a separate converter that plugs into the 12v socket and has the option to select the converted output, which is 18V for the TV. It works fine and does not cause any significant drain on the battery. I can switch between 110 and 18V depending on power availability. However, I still need 110 to run the DVD player.
07-20-2009, 12:09 AM
Airstream Handyman
1973 23' Safari
1970 27' Overlander
1959 24' Tradewind
1975 20' Argosy 20
Phoenix
Good 12v LCD TV
Target.com sells a good Skyworth 19" LCD TV that runs on 12v. I have them in two of our units and they work well. I like an external 12v DVD player rather than the built in ones. Makes it easy and cheap to replace when they die (not if).
John
07-20-2009, 04:18 AM
1993 34' Excella
Estancia
It is my opinion that manufacturers and their minions don't know what to do with questions that deal with out of the box thinking. In that case they usually C their liablility A and say something like that application is not recommended.
As far as I know 12v DC is 12v DC, although the voltage coming out of a battery does vary from 13v+ to 12v- depending on the level of charge.
07-20-2009, 07:33 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
there are televisions that are made to run on 12v. Mine has both a 110v plug, as well as a 12v (cig lighter) plug.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
07-21-2009, 04:52 PM
San Diego
We have a 19" Polaroid LCD with DVD we got from Target. It is a 12 volt unit that had a 120v inline transformer with it when we bought it. We don't have to use the inline transformer. I bought a cigarette adapter plug from Radio Shack and pluged it in to the line for the TV an viola! No inverter.
Randy
07-21-2009, 04:58 PM
2006 28' Safari SE
Colorado Springs
Inverter?
Yakman,
Do you have an inverter? An inverter uses the 12 VDC from the battery and converts it to AC. That is how our TV works. Let's us use it boondocking. Takes very little power.
-KL
4CU Charter Member
07-21-2009, 05:34 PM
Gahanna
Hi Silverback,
Inverter? Heard of them before but not sure if I have one or not. My spec sheet from AS for my unit doesn't specifically list one. Under battery power I can turn on my interior lights and play my stereo/cd changer but no television.
I have a small electrical panel under my bed that hums and vents but not certain if that is an inverter?
If I can run the lights, pump and stereo under battery power, should my TV be able to be turned on?
thanks,
yakman
07-21-2009, 05:41 PM
1995 25' Excella
1982 34' Limited
Albuquerque
An inverter is not the way to go. You are suffering losses in the conversion from 12vdc to ac and then back to dc. If you doubt this, simply run your inverter under load for an hour then put your hand on it. The heat you feel comes from electrical losses. Larger inverters even have a cooling fan that wastes even more electricity.
Simply do a google search for 12 volt tv and you will find lots of options. I use a 12 vdc HD TV in my Airstream with good results.
Airstream25
KE5CKG on 2 meters
AIR #10274
07-21-2009, 05:54 PM
1978 28' Ambassador
Morada
Sure, an inverter is not 100% efficient when converting from 12VDC to 110VAC, but the newer, solid state, types are good enough that you'll probably not notice...
With an inverter, you don't have to limit your search for a 12VDC TV, or DVD player...get the ones you want, use an inverter, and recharge your batteries with your generator each day to keep em' topped off...
We use an 1500 watt inverter so we can use it for other stuff besides the TV, Sat receiver and DVD player...blender, computer, phone chargers, etc...the only detractor, most larger rated inverters have biscuit fans to keep em' cool, and you can hear the fan running at a low hum...
We plug our TV, DVD, SAT receiver, SAT antenna operator, into one AC surge protector...we can then plug this protector into the inverter when on batteries, or plug it into the standard trailer AC receptacle when on shore power...works great and the expensive electronics are protected from surges when we're at RV parks as well...
Ray & Pat; Morada, CA
07-25-2009, 01:51 PM
Chief Chili Cook
2010 30' Flying Cloud
Bakersfield
yakman, we've got the same 2007 25FB International CCD. Ours didn't come with an inverter. We recently replaced the 19" Sony TV with a 22" Vizio so we can watch over the air HD. The first night I ran it off a small inverter and measured it's power usage with a Kill-A-Watt meter. It uses about 42 watts.
After playing a DVD (with built in factory installed Sony MEX-R5 DVD Player) in a continuous loop for about 5 hours, the battery meter said I had about 90% batter charge left. That was at night, so the 80 watt solar panel on the roof wasn't charging.
The inverter I picked up was Black & Decker PI100AB for $17 at walmart.
