Old 06-23-2008, 09:18 PM   #1
2012 25' FB Flying Cloud
Greenwood Village , Colorado
Second Television in 25 Safari SE FB
Can anyone share their experiences with a bedroom TV in a Safari 25 FB?
If you have one, did the dealer install it or did you do it yourself?
Also, if you have a satellite receiver, where have you placed it? The line-in seems to be in a strange spot (under the dinette table).
Thanks for any information and my apologies if I've started a duplicate thread.
Hyperion is offline   Reply With Quote
Old 11-07-2008, 08:31 AM   #2
2008 25' Safari FB SE
Buford , Georgia
Hperion, I have the same question on mounting a TV in the Bedroom of my safari 25 fb. Were you able to get your installed? If so how.
FosterSafari is offline   Reply With Quote
Old 11-07-2008, 09:05 AM   #3
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Are you talking about installing a television that operates on cable, satellite, or rabbit ears?
willyd is offline   Reply With Quote
Old 11-08-2008, 09:13 AM   #4
Denis4x4's Avatar
Durango , Colorado
Our second TV was dealer installed as the cable needed to be routed behind the refer and shower stall. I use a Dish Network box with a dealer installed King Dome. This is a box used in the shop so it is always activated. I put in in the upper left cabinet over the dinette with the CD box and Serius radio. There is a switching box to go from park cable to Dish Network. With park cable different programs can be seen on each set. Same program on both sets with Dish Network box
The FB set was originally installed directly on the wall and was a disaster. If you look carefully, you can see where the dealer mounted it by the thermostat. I used a piece of oak with short #12 wood screws and glue to spread the load. The TV mount uses 1/4 X 20 bolts and T-nuts. No problems after two years with this setup.
The local Dish Network/Direct TV dealer does a lot of RV installations. After having some work done by the local stereo installers, I wouldn't hesitate to use them for Airstream work.
Don't drill through the bulkhead into the shower stall!!!
ID:	71068   Click image for larger version
Denis4x4 is offline   Reply With Quote
Old 11-16-2008, 04:09 PM   #5
2007 25' Safari FB SE
Evergreen , Colorado
Our 25FB was pre wired. I used the same arm setup that was in the front, it works fine. My question to you would be, what is the best satelite antana to instal for a Dish service. I have done some reserch but am still in the dark.
Allen H is offline   Reply With Quote
Old 11-17-2008, 09:25 AM   #6
extiger's Avatar
2011 30' Classic
Kingwood , Texas
Hyperion asked "if you have a satellite receiver, where have you placed it? The line-in seems to be in a strange spot (under the dinette table)?"
We use a portable dish on a tripod and run it to the satellite receiver that is stored in a water resistent "Rubbermaid Actionpacker" and run a cable from there to the TV cable input located in the rear bumper storage box. The Actionpacker is stored under the trailer. We are able to use the remote and don't have the satellite receiver in the inside of the trailer under foot. Additionly the Actionpacker serves as the storage container for our satellite gear, such as cables. The only drawback is that both TVs get the same channel. That is not a problem for us as rarely do we want to watch two different programs at the same time.
extiger is offline   Reply With Quote
Television Cable cameront120 Audio, Video & TV 6 10-07-2017 05:37 AM
Television Program Inland RV Center, In Airstream "In the News" 18 03-31-2013 11:39 PM
Help with Television Selection straya Audio, Video & TV 15 05-17-2008 08:00 PM
Mounting television bracket on black television shelf PWRSTRK Audio, Video & TV 3 04-24-2005 02:04 PM
