Old 02-21-2008, 07:46 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Satellite vs. off air TV
I am undecidedly ignorant about satellite vs. off air TV reception while Airstreaming. I have satellite service at home.
Would manually orienting a satellite dish be too time intensive for short stays?
Is there a manual unit that roof mounts?
What about manual combo off air and satellite units? Any such animal? Can I have my cake and eat it too?
I have only mentioned the manual units because the little I have seen about the automatic ones is they are very pricey?
Old 02-21-2008, 07:59 AM   #2
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi,
Yes you are right most automatic units are very costly. Most camp grounds we sty in have cable tv. Why not just buy a long coax cable for 20 dollars and be done with it. Of course if you are in the boon docks even the Satalite TV will not work.
Normal set up with a manual unit schould take about 10 minutes since you can buy a signal meter that will tell you signal strenght.For short stay in camp grounds use the cable.
Regards from Russell in sunny and warm Tucson Az.
RUSSELL is offline   Reply With Quote
Old 02-21-2008, 08:13 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you camp around trees you do not want a roof top system.
The older receavers are much easier to use to aim the antenna. For some reason the newer ones are not user friendly. Satellite will work any place you can see the southern sky where as off air will only work within about 50 miles of town.
I have wired for both. Just turn thr amplifyer on for off air or turn it off and tune to channel 3 for satellite
The 2 systems are completely different so I doubt there will ever be a combination.
Name:	cable inside.JPG
2004 Excursion 4x4
Old 02-21-2008, 08:17 AM   #4
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Check out the automatic satellite systems below:
King Dome Satellite Systems on Sale
Don
adonh is offline   Reply With Quote
Old 02-21-2008, 12:05 PM   #5
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Winegard® Crank-up Satellite Dish - Camping World
Here's a manual roof top dish. I haven't used one but a friend who has an automatic dome mounted dish had one on a prior rig and says he wish he had one again instead of his automatic unit.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 02-21-2008, 02:06 PM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I have heard that the old batwing antennas work very well for the new digital high definition signals that are mandated for next year. You will likely end up buying a flat screen for your Airstream next year. I have used satellite on the road a number of years and you definitely do not want a roof mount if you camp in state parks or other treed areas. Winguard has a nice portable antenna unit sold thru Camper World which allows you to place the antenna anywhere you can see the southern sky. Another concern is using the pay for view features. They will not work unless you have a land line phone line available. For short stays have fun sightseeing and forget the tv. If you are using commercial campsites cable for $1.00 + per night is cheap entertainment and it will take a long time to pay off the equipment expense for automatic satellite.
Old 02-21-2008, 06:58 PM   #7
Halimer
2006 25' Classic
New Hyde Park , New York
You may want to check on the VuCube satelite receiver.
Vu Qube Portable Satellite TV Antenna - Camping World
halimer is offline   Reply With Quote
Air pressure in front air bags on LY Santart Land Yacht/Legacy Motorhomes 1 08-29-2007 09:50 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Using Satellite tv ALANSD Electrical - Systems, Generators, Batteries & Solar 46 04-22-2006 08:22 PM
Air pressure for rear air bags Jon Smith Towing, Tow Vehicles & Hitches 2 08-12-2003 09:08 PM
Satellite from above 53flyingcloud Our Community 14 03-29-2003 09:46 AM
