Old 08-30-2010, 09:23 AM   #1
akirkbride's Avatar
1984 29' Sovereign
Phoenixville , Pennsylvania
Salvaging existing antenna
Our "new" 1984 A/S Sovereign has the original antenna on top - with (what appears to be) an antenna connection in a cabinet to the left of the door. One of the plugs looks like a cigarette lighter receptical, and the other has two holes and is identified on the cover as "Antenna" (no coaxle hookup).
Is there anyone who has found the right cable to connect to the interior receptical and possibly used a converter with any success? As new A/S owners, we kinda want to keep her all as she is...but if we need to consider other antenna options, I guess we (reluctantly) will...
Thank you for any suggestions you might have for this newbie owner!
akirkbride is offline   Reply With Quote
Old 08-30-2010, 09:54 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
cigarette lighter receptical - a 12V supply
does the orig annt have a cable on the topside? The old wire
was 2 strand, brown, flat wire.
If yes, then begin to trace the route from outside top
to inside. Ya need a wire(or cable). My suggestion is to
run new coax alond the old cable's route....sealing with caulk
as you go. The new coax can be terminated as you wish.
ant wire is usually only two strand(very simple).
kennethowens is offline   Reply With Quote
Old 08-30-2010, 09:56 AM   #3
blickcd's Avatar
Milford , Ohio
The two holes are for a twin-lead cable plug. You could probably find one of those at Radio Shack, along with the proper adapter to connect it to the coax jack on your TV.
The previous owner of my trailer had taken that box apart drilled a hole in it, and soldered in a piece of coax cable that hung out a few feet.
Christopher
blickcd is offline   Reply With Quote
Old 08-30-2010, 10:25 AM   #4
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
You will find the original twin pin plug for the 300 ohm flat antenna lead is still available.
Brown 2 PIN Plug 13174 [13174] - $3.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
The following photos are courtesy of Out of Doors Mart website.
Name:	Two Pin Antenna Plug a.jpg
Name:	Two Pin Antenna Plug.jpg
You will also have to add a 300 ohm to 75 ohm balun ( matching transformer) to be able to connect the flat wire to the 75 ohm coaxial input of most modern television sets. This is how I hook up my new flatscreen and it works fine with the old wiring and antenna as long as I'm within decent range of a television station transmitter.
I hope this helps.
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 09-01-2010, 05:30 AM   #5
akirkbride's Avatar
1984 29' Sovereign
There is a cable topside. I think I can trace it and try to replace the existing receptical, as you indicated. Thank you so much for your help!
Old 09-01-2010, 05:32 AM   #6
akirkbride's Avatar
1984 29' Sovereign
Thanks to everyone for the photos and links, as well as the excellent advice. I think I can do this - with the good direction and advice you all provided.
Thanks, again! I'll be sure to post any discoveries I come across along the way, in case anyone else is ever nuts enough to do the same.
Old 09-01-2010, 07:17 AM   #7
funkill's Avatar
reno , NV
Images: 27
I DO need to do the same thing ... been puttin' it off due to intimidation....
Please let us (me ) know how it goes!
Laura
funkill is offline   Reply With Quote
Old 09-02-2010, 05:20 AM   #8
akirkbride's Avatar
1984 29' Sovereign
Laura
Will do, Laura! We have a couple of other items to tackle first, but as soon as I get to it, I'll keep posting my progress!
Austin
Old 09-02-2010, 07:01 AM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
When I inspected the analog antenna on my trailer right after I first got it, it appeared solid on it's mount and it was, but the signal wire leading into the trailer had a broken lead right where it entered the trailer body. I tried to pull up the lead and see if there was enough slack to splice but I couldn't get even one inch of slack to pull up. I removed the antenna, and still the cable wouldn't give up any slack. There might be a trick to repairing that cable I didn't see. It wasn't a modern coax cable, it was sort of flat and fat with the leads side by side.
Old 02-02-2011, 05:21 PM   #10
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
Did you ever run new coax to replace the two-wire? We have a '83 Sov that I'd like to try that, too. I'd like to know if anybody has had success pulling new coax from the topside aircraft to the panel on the SS wall.
Alsupp is offline   Reply With Quote
Old 02-02-2011, 06:29 PM   #11
aname4me's Avatar
1988 25' Excella
Thunder Bay , Ontario
A newbee question.... when working on the roof (antenna)
Can the roof take a man's full weight? or do you have to do a lot of reaching from a ladder?
aname4me is offline   Reply With Quote
Old 02-02-2011, 07:16 PM   #12
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
I am 250 pounds and can stand on the roof where there is a rib, ONLY stand on a rib.
You can tell where the rib is by the rivet line going across the trailer, not the rivet line going front to back.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 02-02-2011, 07:23 PM   #13
Splitrock's Avatar
This is how I dooooo it
http://www.airforums.com/forums/f478...oof-66345.html
Old 02-03-2011, 05:23 AM   #14
1973 31' Excella 500
Spring Green , Wisconsin
The safest way to work on any item on the roof of your Airstream is either from a ladder (with padding) or from a platform spanning the width of the trailer and supported on either side. IMHO.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Question of Existing Floor Penetration 66Tradewind 64Overlander Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-22-2009 08:18 AM
Mounting blinds in existing curtain tracks Maryw164 Upholstery, Blinds, Walls & Interior Finishes 1 05-03-2009 05:48 AM
Is anyone salvaging a '77 24ft Argosy by chance?? BigMike Repairing/Replacing Floor &/or Frame 7 08-26-2008 03:59 PM
Adding a barbeque addapter to existing copper lines letsgo LP Gas, Piping, Tanks & Regulators 3 10-12-2005 10:02 PM
