10-22-2017, 07:50 PM
#21
2004 28' Classic
Monument
Jim,
Which paragraph do I need to look at??
Dave
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
10-23-2017, 04:54 AM
#22
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
Hi Dave,
Choose add camera from the MobilincCam app, go To the middle of page 7 on Fred's instructions. The only thing I entered was a camera name, protocol, ip address, and maybe port. The hook up then started to work. Good luck. Jim
10-23-2017, 07:16 AM
#23
2004 28' Classic
Monument
Thanks Jim.
DaveP
2023 Ram 3500 4x4
10-23-2017, 09:35 AM
#24
2014 25' Flying Cloud
Cuddebackville
, New York
Good work Jim. Is the app Mobilink Cam Viewer ($9.99)? I also see a few similarly named apps.
2019 Ford Expedition Platinum
10-23-2017, 10:05 AM
#25
1997 25' Safari
Burlington
, Ontario
Yes. It was the one recommended in your link to the camera maker. Jim
10-28-2017, 12:42 PM
#26
1997 25' Safari
Burlington
, Ontario
I had a chance to test the iPhone, router, and camera performance this weekend on a short camping trip. There is an issue where, periodically, the image on the phone freezes for about 10 seconds and then resumes by itself. It is random. There does not seem to be a pattern. It seems to be loosing contact with the router and then re-establishing its connection. I will try setting up the phone again using only Sharx's instructions for Mobilinc Cam Viewer app set up to see if that fixes the issue. My fear is screwing up Fred's established link between the camera and the router and then having to start over. Jim
11-01-2017, 07:09 PM
#27
2004 28' Classic
Monument
I finished doing my reinstall on Sunday. I basically did everything that Jim did. It appears to work just fine.
DaveP
2023 Ram 3500 4x4
04-07-2018, 11:30 AM
#28
Cuddebackville
, New York
I finally got around to trying Mobilink Cam Viewer. Although it was easy to set up, I only got a good picture for the first couple of minutes. Then it started continually cutting in and out. This is while I was inside the trailer so it wasn't a range problem. I tried rebooting to no avail.
Anyone else have any updates?
04-07-2018, 11:58 AM
#29
1997 25' Safari
Burlington
, Ontario
Hello Wayne &Sam,
I am experiencing the same issue although the on time is significantly more than the off time so I reluctantly put up with it. Not the best situation but, perhaps like you, am waiting for a fix from the heavens. Jim
04-07-2018, 12:35 PM
#30
Walnut Creek
We struggled for a long time with the cost of a Voyager camera. Finally bit the bullet and had it installed. Absolutely no regrets about the money as it was well spent. We are quite satisfied with the capability. You can do without it, but a rear view camera makes travel and parking so much easier. Pat
04-11-2018, 08:00 PM
#31
Durango
Wayne&Sam,
Just found this thread. Any up dates on the system. How MobiLinc Cam Viewer is 9.99 is that the app that integrates with Fred's Camera System. He did answer me and that is what he indicated.
Ken
04-12-2018, 09:45 AM
#32
Cuddebackville
, New York
Originally Posted by pkm123
Wayne&Sam,
Just found this thread. He did answer me and that is what he indicated.
Ken
You've had contact with Fred?
That is the app I'm trying.
04-12-2018, 05:12 PM
#33
Durango
Wayne,
Yes and he texted me that MobiLinc was the app and to use the same IP address and settings and it will work. I am not sure if he is talking about the Wi-Fi settings on the iPhone or the add camera in the app. Can you send me a screen shot of what to put in each line of the add camera in MobiLinc app. I have tried everything and can’t get it to recognize the Sharx camera. It is not clear in Fred’s printed instructions either. They don’t match the choices in the app.
Ken
04-12-2018, 05:38 PM
#34
Cuddebackville
, New York
Pretty simple Ken.
Camera type: Share
Local http:// 192.168.168.100 Or what was in Fred's instructions, I assume it's the same
Local Port: 80
Then it's just your user name and password that Fred provided.
All the info I entered came off Fred's instructions.
I'm glad you heard from him, we were worried about him.
04-13-2018, 08:36 AM
#35
2004 28' Classic
Monument
Is this new Mobiliinc Cam Viewer really $48 or am I looking at the wrong app in the Apple app store?
DaveP
2023 Ram 3500 4x4
04-17-2018, 04:24 PM
#36
1997 25' Safari
Burlington
, Ontario
I paid about $10 for it. Mobilinc Cam Viewer. I am getting weird quotes at the App Store and don't see anything there for $10 anymore. Don't know what to say about it. Jim
04-17-2018, 09:27 PM
#37
Durango
Hey Wayne,
Thank you for your response. I was trying to post a response for several days and Safari kept telling me there were too many redirects or some such BS. Finally figured out how to go into Safari Preferences and fix that. It was on Safari's end and not the forum. I was finally able to get the Mobilinc app to recognize my Sharx camera that came with Fred's system. I used it this weekend on a 150 mile trip to Canyon Lands for a test run. IMO it seemed to be much more stable than the IP Vision app. which no longer is available. The only issue that it seems to have is freeze framing every so often for only a matter of seconds and was not in anyway as limiting as when my screen on my iPhone 7 would start to pixelate and then totally freeze for several seconds to minutes. (I have the latest OS on my phone by the way). I have my phone in a light protective case in a dash mounted cradle and kept the ac vent on it for the trip. This helped with the IP vision app. as well. Not sure if it was the phone heating up or the app or both. There are no screen exposure adjustments on the Mobilink app. There were various adjustments on IP vision but the only thing I usually adjusted was brightness. The Mobilinc app is up on the app store for the cost of 9.99. I think Jim was asking about that. I just downloaded it a few days ago. There was another option of Mobilinc Pro for 49.99. Hope this adds to the general pool of knowledge on Fred's rear view camera system. Thanks again for your help.
Ken
05-29-2018, 08:55 PM
#38
Bill Crockett
2012 27' FB International
Parker
Okay.... I found the Apple iOS app that works with the Camera and Router Fred Stoke sold me. It is MobiLinc Cam Viewer and it was free to download it. It is the App recommended by Sharx, the camera manufacturer. Here is a summary of the setup process I used:
1. Use Netgear Router admin app to lookup the IP address for the camera. ( http://Routerlogin.net) ID = admin, Password = password. Under devices attached you can find the IP address. My camera is 192.168.168.100
2. Download the MobiLinc Cam Viewer App from the AppStore
Configure as shown below:
Cam settings
Camera Name: Airstream Camera
Camera Type: Sharx
Local http://192.168.168.100. (Your ip maybe different)
Local Port 80
RSTP Port 80
Away http://192.168.168.100
Away local port 80
Away RSTP Port 80
Leave all the other fields blank including ID and pasword. Scroll down and confirm and save
05-29-2018, 08:59 PM
#39
Bill Crockett
Parker
I just downloaded it and is was free. Maybe the stop charging version I am using.
06-02-2018, 09:43 PM
#40
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
I am reconfiguring my Rv Rearview camera with the Mobilinc app on a new iPhone. Can someone who has the system remind me of the default router password that Fred provided with the unit? I can’t find the original paperwork. Thanks! Joe
