Old 01-20-2016, 08:53 PM   #43
rp709's Avatar
2015 30' Flying Cloud
Ventura , California
Must you activate the clearance lights in order to power the backup camera?
rp709 is offline   Reply With Quote
Old 01-20-2016, 11:23 PM   #44
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Depends how your camera is wired. Our camera is on all the time unless we explicitly turn it off via a separate switch. Others have indeed wired their camera via the trailer lights so it only works when the lights are on.
Rocinante is our 2014 International Signature 27FB
Old 01-21-2016, 04:18 AM   #45
walker's Avatar
1987 34' Excella
Asheboro , North Carolina
Camera power
With the clearance light power feed, yes clearance lights must be on to power camera. Im ok with that since I like to run the lights anyway and is only convenient switch Ive read about. My solution to the lack of slack in the wiring was to cut a larger hole behind the center clearance light. Also, there is probably more slack available behind the curb side clearance light of the 3 light group. Good luck. You will love the camera
walker is offline   Reply With Quote
Old 01-21-2016, 08:50 AM   #46
2015 28' International
Aloha , Oregon
We tapped into the USB power supply in the back closet via a switch we mounted right next to it, so we can power the Voyager anytime we want independent of everything else.
garybair is offline   Reply With Quote
Old 04-26-2018, 05:07 AM   #47
Virginia Beach , Virginia
I found that popping out the grommet on the center clearance light made it easy to get 4 or 5 inches of wire to make my connection. It also allows space to feed the camera wire up through the hole to make connections.
petermday is offline   Reply With Quote
Old 05-16-2018, 10:47 AM   #48
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I just used my voyager 4.3 for the first time. No dropouts or loss of connection at all. The camera is very wide angle, objects are WAY closer than they appear , I have to get used to that. Not as clear a picture as my previous (Fredís) system but totally adequate.
I mounted the camera inside looking out the back window through the screen. Now that I know it works, Iíll mount it outside. Iím thinking of cutting off the connector and tapping power from inside the clearance light fixture
2012 Dodge Durango Hemi/AWD
Old 05-21-2018, 10:17 AM   #49
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
How do you remove plastic cover on clearance light? Brut force ?
Castaway is offline   Reply With Quote
Old 05-26-2018, 05:38 PM   #50
2015 28' Flying Cloud
Mesa , Arizona
Newbie here. Really interested in this thread. Just bought a 2015 Flying Cloud 28RB in Ohio and towed it back to Arizona. Trip went well, but highlighted the need for a rear view camera.
Trying to decide between the Tadi Brothers Model SKU90113 and the Voyager WVOS541. Anybody have any experience with the Tadi Brothers system?
Also interesting in mounting the camera outside, without drilling a hole in the body. Am considered using 3M or equivalent exterior rated double sided tape, but wondering if it will hold up at highway speeds.
Thanks in advance for your help.
shermanjenni is offline   Reply With Quote
Old 06-22-2018, 01:02 PM   #51
Wayne&Sam's Avatar
Images: 21
After opening the clearance light I see that they didn't leave any slack in the wiring, as others have found.
I guess I'll be drilling a new hole after all.
I was also thinking of using 3M HB tape to mount the bracket, but it has so many holes and slots in it that I on't think they'd be enough contact area.
Old 07-06-2018, 06:16 AM   #52
Wayne&Sam's Avatar
Images: 21
The hardest part of the installation was drilling that 3/4" hole in the exterior skin. Emotionally hard, not physically.
I used the supplied grommet and it captured both the bracket and the skin. Wired it to the reading light (as I had done for the previous interior mounted camera. Added a switch with a pilot light on it. I also left enough slack in the wiring so I can pull the camera connector out through the skin if I need to replace the camera.
Old 07-06-2018, 07:05 AM   #53
madison , Wisconsin
splice
I pulled off center clearance light, ran a wire from camera below and used a quick splice from hardware store. Quick, easy, works.
From Amazon: Morris Products 10774 Quick Splice Connector, Blue, 18-14 Wire Range (Pack of 25)
garen-kary is offline   Reply With Quote
Old 07-30-2018, 05:40 PM   #54
Wayne&Sam's Avatar
Images: 21
Gotta day I really like the Voyager now that Iíve traveled s bit with it.
Old 07-31-2018, 05:23 AM   #55
Had the same issues with connecting to the center running light. I just popped out the grommet under the light and it freed up about four inches of free wire. That was plenty of slack to make my connections. I've been using it now for about 7,000 miles and it works great and I couldn't go without it.
Old 08-01-2018, 06:54 PM   #56
Wayne&Sam's Avatar
Images: 21
I couldnít get any slack on my clearance light. Zero.
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
1993 airstream 190 b class~sleeps 3~nicely equipped~rear view camera~flat tv~wow eBay Watch Airstreams on eBay 0 01-27-2012 04:40 PM
Rear View Camera and Monitor. cooperhawk General Motorhome Topics 19 04-18-2008 04:10 PM
Rear View Video Trailer Camera Mount Location chaimemet Towing, Tow Vehicles & Hitches 10 02-07-2008 08:15 PM
Sony Rear View Camera gunworks Electronics & Connectivity 1 10-08-2005 01:27 PM
