Old 04-10-2016, 12:42 PM   #1
cbrittan's Avatar
2016 30' International
Woodstock ON , North Fort Myers FL
Round TV Antenna
Our 2015 International Signature does not have a 12v wall receptacle which typically includes the TV signal Amplifier (little green light on/off). There is no access to 12v power anywhere inside this AS. This is because this model AS has ducted air (no access to the rooftop for the up/down antenna) This rooftop antenna is round and requires no turning to capture a HD signal.
This is most likely a "Wineguard" or similar common circle antenna which according to this company spec, requires a 12v amplifier.
If there is a 12v HD TV amplifier in our AS, it's well hidden. Or more likely, there is no amp even though the antenna might be designed to have one for best signal strength.
We think our HD TV reception would be much more stable if we had such an amp as we had in our last AS.
Ideas and comments will be appreciated.....Thanks!
cbrittan is offline   Reply With Quote
Old 04-10-2016, 12:50 PM   #2
Llando88's Avatar
2016 30' Flying Cloud
That sounds pretty suprising not to have a powered omni antenna.
Our '16 FC FC with ducted air has the black amp button on the TV jack receptable just behind the TV on the fridge wall. Press in, lights up, etc. We turn it off for cable TV, as per the manual.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 04-10-2016, 12:52 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Your trailer does indeed have an antenna booster. Depending on the model, it can be located behind the main television, near the inside wall, or under the dinette, on the wall itself.
Old 04-10-2016, 01:19 PM   #4
2015 28' International
Ofallon , Missouri
Our 2015 28 international has the power under the dinette on the outer wall.
mpsgolf is offline   Reply With Quote
Old 04-10-2016, 01:23 PM   #5
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
It should be up under the dinette on the wall.
silverlabs is offline   Reply With Quote
Old 04-10-2016, 01:25 PM   #6
cbrittan's Avatar
Well, thank you all.
You are absolutely correct. Indeed, we do have an antenna booster on the wall under the table, presently visually obstructed by 'stuff'. We are presently connected to cable, and the light was on. No wonder the cable picture was so nasty. Turned off the green light, perfect cable TV.
Unfortunately, we do not have a 12v access input as in our past AS. We miss it having no way to use the TV when not on shore power. Bummer eh!
Old 04-10-2016, 01:29 PM   #7
silverlabs's Avatar
Waxahachie , Texas
Turn on the inverter and change into one of the inverter plugs for the TV. Works fine when on battery.
Old 04-10-2016, 01:37 PM   #8
cbrittan's Avatar
No inverter on this AS as so rare to be away from shore.
Thanks for your solutions!
Old 04-10-2016, 02:38 PM   #9
silverlabs's Avatar
Waxahachie , Texas
Sorry. Forgot that is still an option on these. Most have them already. Shouldn't have assumed.
Chuck
Old 04-10-2016, 03:49 PM   #10
Wayne&Sam's Avatar
Cuddebackville , New York
Images: 21
You're camping, forget the television!
2012 Dodge Durango Hemi/AWD
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
The Wheels Go Round and Round wheel interested Our Community 36 11-05-2008 03:59 PM
Round and Round She Goes thecatsandi On The Road... 21 04-03-2007 03:36 PM
Quarter Round Molding melprice Floor Finishes 7 09-11-2002 10:59 AM
