Old 09-08-2006, 06:59 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Roof antenna on '77
I was reading the owners book it looks like this is for a radio and TV, is that correct.
If so is do they work well or should it be upgraded?
'77 Sovereign Intl 31' CB
Old 09-19-2006, 09:19 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Bump
Old 09-19-2006, 10:11 PM   #3
New Borockton , Alabama
Images: 21
Bob,
Yes, TV and radio. It's probably a Skyliner or Braund. Barker manufacturing had them for some time but I don't know the exact history. I used to have quite a few parts for them for those wanting to keep it original (They actually work very well). The Excella models even had electric models. Parts might still be available and you can call them and see what they have left. Mine works great and I don't plan to change it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 09-19-2006, 10:16 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
I tried cranking it up it all looks good!
So I'll leave it, I hope I remember to take it down before I hit the road
Old 09-20-2006, 06:14 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Good lubrication advisable in all areas that swivel. Binding in those areas lead to high forces necessary to raise antenna with resultant damage to plastic sector gear in head of unit. Replacement parts are available but time consuming to dismantle and replace. An ounce of prevention is worth a pound of cure. It pays to climb on the trailer roof to get it properly lubricated. Use a small amount of grease that will stay in place for a while instead of light weight oil. Check the antenna booster amp located in the wall outlet if you want good signals in more remote locations.
Old 09-20-2006, 09:56 AM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
I don't see anything else all I see is an antenna wire thru the wall?
What does it look like and where might I find it?
Old 09-20-2006, 10:02 AM   #7
Images: 21
Bob,
It looks like a wall light switch except it has a button for boost and possibly a 12 volt power supply integrated with it. You might not have one so don't kill yourself searching for it. My 76 Sov. did not have one.
Old 09-20-2006, 10:08 AM   #8
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Can I just get something like this at Radio Shack?
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
TV Antenna lead fdx753 Audio, Video & TV 14 04-27-2004 08:45 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
