Old 10-12-2016, 11:47 AM   #1
2012 27' FB International
Boulder , Colorado
Replacing TV's in 2012 27FB International
Has anyone replaced both TV's? And is so, which brand and model # did you use and were there any issues? The TV in our bedroom has a faulty headphone jack and we are going to be able to get a couple of free TV's when we upgrade our cell phones. MIght as well upgrade the living room one as well.
Just wondering what to get that will be plug 'n play and won't stick out into the aisle in the front or the back, or require any cable adapter problems. We do not use the DVD player so the HDMI wiring is not an issue. Just hoping someone has already done this so I don't have to reinvent the wheel.
motozen is offline   Reply With Quote
Old 10-12-2016, 01:19 PM   #2
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Did you measure your TVs in order to compare them size wise to what you are getting? The mounts for flatscreens are pretty standard within size ranges. Every year TVs are getting thinner and thinner. If you are only using the 75 ohm coax and not the HDMI input, pretty much any modern, decent TV should have that option and should be "plug and play".
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 10-12-2016, 01:29 PM   #3
2008 27' Safari FB SE
Long Beach , California
I replaced the front TV, but my AS is older than yours. No HDMI on mine, still the old-fashioned red/white/yellow RCA cables. I was able to find a TV with RCA audio output so can still use the stereo speakers, but no video so cannot use DVD. No problem for us, as we have a computer hooked up for movies.
If you don't want to stick out beyond the cabinet, you'll need to measure the TV dimensions along with where your wall mount sits. If your wall mount isn't perfectly centered along the wall, you should adjust for that in your measurement. My TV sticks out about an inch, but that's only when it's secured for travel. When we are watching, it's angled a bit so that it doesn't stick out.
Much happier with the larger TV than the original TV. Also, as Soyboy mentioned, the newer TV is much thinner and lighter than what the AS came with.
LBOskiBear is offline   Reply With Quote
Old 10-12-2016, 03:57 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
A few Insignia TV's (Best Buy in-house brand) operate from 12 volts DC supplied by an external power supply. If you get one of those (or some other 12 volt TV) you can watch TV without shore power, if your trailer has a 12 volt outlet near the TV. Our bedroom TV is 12 volt but the living room one is not.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-12-2016, 04:00 PM   #5
2015 28' International
Ofallon , Missouri
I had a 2006 25FB not long ago and I replaced both with off the shelf TVs from Best Buy. Just measure your spots and decide how big you can stand. I did go a few inches bigger on both than original but I can't recall the exact sizes now.
My current 2015 28' international has two TVs, and they are both too small for my liking. If anything ever goes wrong with either, I will be enlarging them slightly for sure.
mpsgolf is offline   Reply With Quote
Old 10-12-2016, 04:06 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Whatever you get, I suggest two different brands. It's annoying when we turn on the TV in the "great room" 😀 and the TV in the bedroom goes on too #FirstWorldProblems 😳😉
Old 10-13-2016, 11:32 AM   #7
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
1. Removed & sold the small TV in the bedroom.
2. Removed the smallish TV opposite the galley & put it in the bedroom.
3. Bought 40 in Samsung (~$400) & mounted in on a rotatable mount (~$100) where the smallish TV used to be.
4. Samsung stored vertically when travelling & rotated horizontally for watching.
5. Now can watch college & pro football games in detail. Huzzah!!!
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 10-13-2016, 11:44 AM   #8
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Shoehorned a Samsung 40 inch 4K on the wall above the dinette in our 2016 28ft Flying Cloud. It replaced the 28 inch Samsung factory installed unit. Installed a new wall mount to ensure no problems with the additional weight and size. No issues after a 13,548 round trip to Alaska. Fabulous 4K picture and the TV connect to my WiFi router to access Netflixs for movies.
tsunami is offline   Reply With Quote
Old 10-13-2016, 05:33 PM   #9
2008 27' Classic FB
Ontario , Oregon
Replace TV
I too have been thinking of replacing my 2007 TV with a new Samsung...lighter and much better picture. The TV is mounted on the refrigerator wall. To replace the TV I will need to pull the cord out of the wall and snake the new cord back through. Does anyone know what the black sticky "gap filler" is that Airstream uses to fill the hole in the wall?
Kerry
Shiloh4570 is offline   Reply With Quote
Old 10-13-2016, 07:06 PM   #10
I don't know what Airstream uses but I have used a product that is generically known as self-vulcanizing tape. IT comes in a roll with a separator paper. When you press it together it vulcanizes into a solid rubber mass. It it great for wrapping external electrical connectors, etc. and can probably do a great job of filling the hole.
Al
S/OS #004
Old 10-13-2016, 08:44 PM   #11
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
We bought two Vizio''s from Best Buy. 32" in the lounge area and added a 24" in the bedroom. Because the bedroom was a new installation, we raised it higher than factory. Glad we did! HAPPY! HAPPY! HAPPY!!
Ronman is offline   Reply With Quote
2012 Airstream International 27FB eBay Watch Airstreams on eBay 0 03-15-2013 02:30 PM
2012 Airstream International 27FB eBay Watch Airstreams on eBay 0 02-27-2013 05:30 PM
Newbie: 27FB International; Possible with 2012 Durango/Hemi or Suburban 1500? hrthelr Airstream Trailer Forums 18 05-06-2012 02:40 PM
International Signature Series :: 2012 Airstream 27FB rsletsky Airstream Registry Discussions 0 09-29-2011 07:13 AM
2012 Airstream 27FB International daveharc Buyer Guidelines 12 08-17-2011 11:17 AM
