06-21-2011, 04:44 PM
2005 19' Safari
2005 19' Safari
new iberia
, Louisiana
Replacing Radio
We have a 1977 overlander with the origin radio and it still works but would like to know if it can be replace with a car radio w/cd player ? Sarah
06-21-2011, 06:34 PM
Retired.
, At Large
Yes. I've done it with our Sovereign. I'd recommend a simple on-off switch on the power supply wires, so you can cut it completely off when the trailer is being stored. You'll have to wire both memory and main power wires together to get it to work.
06-21-2011, 06:48 PM
1993 34' Excella
Estancia
, New Mexico
Or, there are units designed for RV or Marine apps you may like better.
06-21-2011, 07:26 PM
Retired.
, At Large
If the radio is visible in the trailer, the white marine version would probably look a lot better than basic black.
06-21-2011, 07:59 PM
2005 19' Safari
2005 19' Safari
new iberia
, Louisiana
Radio
Thanks for the information, I will check out the marine radio that is another way we could go.The radio is in the stereo cabnet by the door. It folds down. thanks
06-22-2011, 08:14 AM
1961 22' Safari
Union
, Oregon
I've mounted two car radios in my trailers. Not a hard job. Coupled with an antenna from VTS I get very good reception, even better than in vehicle.
I think you could see the one in my Safari by looking in "images" under my profile.
Sam
06-22-2011, 08:50 AM
RGates
1968 20' Globetrotter
Thousand Oaks
I got an HD radio for my '68 GT and installed a cut off switch. Also allows the use of my MP3 player. I went to radio shack and got an antenna. It's great. See photos under globetrotter 1968 summer thread. Good luck.
Randy
06-23-2011, 11:00 AM
Milford
, Ohio
I don't know what the original unit looks like but if it isn't a modern DIN size, you could probably make an adapter faceplate of finished wood and mount the new unit that way.
I rebuilt my old living room credenza and installed an AM/FM/CD unit in it. While you probably won't go to such an extreme if you check my blog you can see how my stereo mounts in a wooden panel.
The power switch like Terry suggested is a good idea and I did the same thing.
Christopher
06-23-2011, 03:55 PM
Ottawa
, ON
Two thoughts:
A marine version of an auto music player will often cost more, simply because they don't sell them in similar quantities.
Instead of an extra switch, in the off-season, simply remove the inline fuse that every car music system has. Every extra switch, button, or knob is just one more item to potentially cause problems down the road.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
