Old 11-13-2017, 12:24 AM   #15
2016 30' International
redondo beach , California
Originally Posted by flht2k View Post
i use the bluetooth from tv to the stereo
great idea!!
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 11-13-2017, 06:39 AM   #16
2014 28' International
Baltimore , Maryland
Originally Posted by Flht2k View Post
I use the Bluetooth from tv to the stereo
Great idea. A caveat though is that RCA/TRSS connections generally have better audio quality than Bluetooths 64kbps headset profile or A2DP 128-384kbps profile.
But it depends on the listeners ears, the RCA cables, and the quality of the receiver. Myself, being deaf, I hardly make the best judge.
wbrown is offline   Reply With Quote
Old 11-20-2017, 07:18 AM   #17
2016 28' Flying Cloud
Brandenburg , Kentucky
Big Upgrade
Went from the 28 inch Samsung to a Samsung 40 inch 4K with a Bose Solo. WOW, made a huge difference in viewing/listening entertainment
Tsunami-v2 is offline   Reply With Quote
Old 11-20-2017, 08:13 AM   #18
AirUSN's Avatar
2013 25' FB Eddie Bauer
Bonita Springs , Florida
Nice, but how does it look as it's pulled away from the wall?
'13 Eddie Bauer 25'
'19 Ram Crew 4x4 Limited
Realtor w/Keller Williams, Fort Myers, Naples area and beyond, SL3388777
AirUSN is offline   Reply With Quote
Old 11-20-2017, 02:31 PM   #19
Static mount like the factory install unit. That 40 inch consumes the entire wall and the static mount holds it's close to the wall and it does not intruding into the dinette seating area. Bose Solo has Blue-tooth so I can stream music from my computer, iPad, or iPhone with quality sound.
Old 11-20-2017, 03:11 PM   #20
AirUSN's Avatar
Oh, static I thought it was like mine. I plan to change out one of the 2 in mine here shortly and I’ll be full time come end of December.
'13 Eddie Bauer 25'
Old 11-20-2017, 04:54 PM   #21
The TV/sound bar survived the grueling round trip of 13,548 miles to Alaska, with zero issues. Trip started here in Kentucky. We also upgraded the television in the bedroom area and it's mounted on the factory installed articulating arm. In the bedroom, getting ready to install a fold down shelf, above the television, so that we can put the 12v DC portable Sony Blu-Ray player on.
Old 11-20-2017, 08:17 PM   #22
AirUSN's Avatar
Glad you arrived safe from KY, as I'm leaving KY as well, but to warmer weather.
'13 Eddie Bauer 25'
Old 11-21-2017, 07:39 AM   #23
Looks like a tight squeeze. I didn’t think a 40 incher would fit. You changed the mount? That’s one of the reasons I went with a 32,could be installed without changing the mount.
Old 11-21-2017, 01:04 PM   #24
Getting ready to head south very shortly myself. Doctor said I seem to be allergic to cold weather and shoveling snow!!!
Old 12-19-2017, 12:01 PM   #25
Randy
Randyf22's Avatar
2015 27' FB International
Portland , Oregon
I installed the same 32” Samsung in our 2015 FB International yesterday. I moved the wall mounting bracket against the inside set of screws holding the mounting block for the TV’s top left corner to barely clear the curvature of the trailer’s wall. Still a bit tight. At some point, I may move the mounting block a 1/2 inch to allow better wall clearance.
Significantly better TV for $190 from a military exchange. Next step is the digital to analog audio converter. I liked the original external speaker setup using the radio’s AUX feature.
Thanks for the idea.
Randyf22 is offline   Reply With Quote
Old 12-19-2017, 12:05 PM   #26
Flht2k's Avatar
sacramento , California
Let me know how you set this up
Flht2k is offline   Reply With Quote
Old 12-19-2017, 12:18 PM   #27
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Sweet. I was going to move to 32 but 40” seems the way to go - I wasn’t sure if it would fit..... Plus I couldn’t find a 4K 32”.
Did you use the factory fixed mounting bracket and did you have to relocate it?
wulfraat is offline   Reply With Quote
Old 12-19-2017, 01:59 PM   #28
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
For those using Bluetooth to the stereo, I tried that unsuccessfully. My Samsung has Bluetooth out, presumable for headphones, and my stereo (non-factory) has Bluetooth in but the delay between the sound and picture was too great. There is an adjustment for it in the TV but it did not appear to be sufficient to cancel out the delay in the Bluetooth link. Presumably the culprit is my stereo, but has anyone else run into this problem and if so, how did you solve it?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Samsung Note 4 to Samsung TV Drcrow Our Community 0 07-07-2016 10:32 PM
Connecting Samsung phone to Samsung TV Drcrow Audio, Video & TV 1 06-15-2016 09:29 AM
Samsung Portable DirectTV PWRSTRK Off Topic Forum 3 01-06-2007 09:42 AM
Samsung Microwave recall andyfuson Stoves, Ovens & Microwaves 0 08-30-2004 03:15 PM
