Old 01-09-2017, 07:48 PM   #15
1999 30' Excella 1000
small town , Maryland
Isbrodsky, Maybe you should wait and go to Canopener or other Airstream event, and see and listen to what others have done to their trailers. The younger generation is up on latest technology. I still have the cassette player in my trailer
streaminwild is offline   Reply With Quote
Old 01-09-2017, 08:15 PM   #16
2016 28' Flying Cloud
Brandenburg , Kentucky
Sound
Removed the factory installed TV and replaced it with a Samsung 40 inch 4K unit. Great picture. I recently installed a Bose Solo 5 sound bar directly under the TV. The sound is great and the ability to bluetooth connect with my iPhone to play music is a huge bonus. Only drawback is that the Solo 5 does not have HDMI capability. If it had HDMI, I could have used the smaller Samsung remote which would have powered on the TV and Solo at the same time. The Bose remote is a learning remote and will control all the functions of the TV, but it requires that you use one button to power on the TV and another for the sound bar. It works well. Since there is only 1 120v plug-in behind the TV, I'm going to change out the single for a double and then plug the Solo in behind the TV and attach the power brick to the back of the TV for a clean looking install.
At some point, I'm going to replace the weak Clarion AM/FM radio with a touch screen unit. I've been eyeing a JVC unit, but will wait to see what the latest will be coming out from 2017 Consumer Electronic Show in Las vegas. Rumor has it, hope, hope, hope, that Audiovox will bring back their 12volt BlueRay DVD player and I'll remove the 120v AC Samsung BlueRay player to save space and power when boon docking.
Name:	Bose Solo Install.jpg
Tsunami-v2 is offline   Reply With Quote
Old 01-10-2017, 06:25 AM   #17
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I am going to try the iLive Sound Bar; the Bose is too expensive for a solution I may not like. I could replace the TV and the head unit for the Bose price. I will try to mount the iLive to the TV bracket or the bottom of the TV.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-10-2017, 07:20 PM   #18
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Replace the SONY audio receiver? Help
I just ordered one of these puppies to replace my 2008 Sony DVD head unit.... (pioneer avh-x3800bhs).
Also going to upgrade the stock speakers with some Polk audio 6.5" full range units as well....
Full 6.2" touch screen with Bluetooth, XM and HD radio support which will be nice. Supports aux audio input from the tv and composite video output to the tv using existing RCA cables. Also has subwoofer pre-outputs. So plug and play with the existing cabling in my 2008 international. Opted against the larger 7" screen as it is motorized to provide access to the DVD slot - figured it would be one less thing to break while bouncing down the road.
Also ordered a bypass signaling unit to enable all functions without a handbrake wired into the system and double DIN frame that I'll set in the existing overhead bin enclosure after I enlarge the current single DIN opening.
I'll post a thread to document the install. Should be pretty straight forward... I'm looking forward to cleaning up the rats nest of wires associated with the current arrangement.
Name:	ImageUploadedByAirstream Forums1484097525.377667.jpg
wulfraat is offline   Reply With Quote
Old 01-10-2017, 08:18 PM   #19
Good luck. I'll be following your install to see how to do mine.
Sent from my iPhone using Starship Enterprise warp drive
Old 01-11-2017, 08:51 AM   #20
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Originally Posted by lsbrodsky View Post
I am going to try the iLive Sound Bar...
Pictures of my install of iLive Sound Bar
Name:	ImageUploadedByAirstream Forums1484146202.240151.jpg
Name:	ImageUploadedByAirstream Forums1484146220.484225.jpg
Greg
greghoro is offline   Reply With Quote
Old 01-11-2017, 11:46 AM   #21
lsbrodsky's Avatar
Thanks!
Larry
Old 01-11-2017, 08:16 PM   #22
greghoro's Avatar
Wheaton , Illinois
Oops, just discovered a problem with the remotes with this combination
When entering 6 on the Samsung TV remote, the sound bar switches to a different input. When entering 7 on the TV remote, it toggles the power on the sound bar.
Strange that the sound bar power toggle button does not change the TV channel to 6
Have to retract my recommendation for the iLive sound bar at this time
Greg
Old 01-11-2017, 10:24 PM   #23
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
I did the Bose Solo5 over the TV and used the HD optical output on the TV to the Bose. Worth every penny in sound and ease of use. It is so much better than the $10 speakers mounted in the ceiling. With Bluetooth who needs the cheap frustrating head unit.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 01-21-2017, 09:00 PM   #24
wulfraat's Avatar
Here are the details for my install:
http://www.airforums.com/forums/f450...ml#post1902186
Old 05-01-2017, 03:37 PM   #25
2013 23' Flying Cloud
Bainbridge Island , Washington
The DSX-S310BTX in my 2013 23D just died, I am told the DSX-A405BT is plug compatible. Has anyone installed a DSX-A405BT?
2013 Flying Cloud 23D
2001 BMW X5 4.4i (TV)
2004 BMW 330/Ci 6-spd
2005 BWM R1200ST
1977 Cessna C177B
warmrain is offline   Reply With Quote
Old 05-01-2017, 07:22 PM   #26
So I just started to read details and understand that the XA-300 isn't going to work with a newer radio. In fact it looks like the XA-300 is pretty useless.
Looking at diagrams it seems the Samsung Bluray is using the same sort of "bus" as Sony. Called something like a Unibus...
At the moment it seems unless I want to start from scratch with all new equipment, it's clarion or perhaps a new model Pioneer...
Is there some new information since January?
I'd like to just replace the Sony Stereo (and XA-300) with something that I can plug and play in my 2013 23D... is that possible?
First choice would be to not enlarge the hole, but I will if that is what I need to do to replace the Sony stereo and Aux-in selector.
Many thanks to anyone that can help.
Best, Cars
2005 BWM R1200ST
1977 Cessna C177B
Old 05-02-2017, 03:07 AM   #27
lsbrodsky's Avatar
I replaced both with a new Kenwood, just plug and play except for connecting all of the wires.
Larry
Old 05-02-2017, 09:43 AM   #28
OK, I think I get it, the AX-300 is only there because the DSX-S310BTX has no other way to have an aux-in. And, the only connection to it is the audio from the TV. All I really need is a stereo with an aux-in?!
2005 BWM R1200ST
1977 Cessna C177B
Sony Audio Receiver/CD Player in '06 Safari resets periodically BRS-Austin Audio, Video & TV 12 03-22-2016 06:30 PM
2010 stock Sony - RCA audio - how to use? Anders79 Audio, Video & TV 8 08-15-2015 12:39 PM
can't get proper sound through Sony receiver and TV Anna girl Audio, Video & TV 5 11-02-2013 11:28 PM
Hard To Replace Sony In '06 Bambi? jambie Audio, Video & TV 19 08-24-2012 01:18 PM
AM/FM/DVD/IPOD audio input receiver info needed oldtrucksrul Audio, Video & TV 16 02-17-2009 09:05 AM
